4K video decoder/ethernet interface
I want to explore Xilinx 4k video decoder/encoder, ethernet interface, decoder/encoder display output.
thank you
khoder
Re: 4K video decoder/ethernet interface
I'm very happy for you
4K video over TCP/IP is interesting. When you consider the bandwidth needed, compresion coudl raise its head.
many IP blocks around, but not cheap , especialy if you want to follow SMPTE
this might be of interest
https://www.smpte.org/sites/default/files/users/user29811/SMPTE%20UK%20&%20SAM%20-%20ST%202110%20The%20Basics%20FINAL.pdf
thank you
Do you know how to contact Xilinx tech support?
Depends what you are spending on chips with them
first point is the forums or who you purchase through
HI @h1khoder
The forums is your way to have contact with Xilinx Technical support. If you need a 1:1 support, you might want to contact an Authorized Distributor.They are sellings the parts and doing the support for small accounts.
I guess what you need is 2*ZCU106 board and to use the ZCU106 VCU TRD. This way you can do (board 1) encode -> ethernet link -> (board 2)decode -> display
Florent
