Visitor houshin
A data buffering problem and some AccelDSP experience to discuss
Hi everyone,
I have a data buffering problem that I can not announce a persistent variable with large size.
If I do so, the AccelSDP will be hanging in the Generate RTL step. Here, I would like to share
some experience. First, if I write the program as follows:
 f
unction y = test(x)
if x == 0
   y = a;
else
   y = b;
end
then the AccelDSP will be hanging during generating Verilog output in the Generate RTL. Therefore, instead, I have to write
the program like
function y = test(x)
if x == 0
   temp_y = a;
else
   temp_y = b;
end
y = temp_y;
The second one is that when I use persistent variables like
persistent a
if isempty(a)
   a = 0;
end
then it is better not using
a = a +1;
this kind of statement which changes persistent variable directly. I have to write like
b = a;
b = b+1;
a = b;
the variable b is not a persistent variable. I guess it’s because it needs one read and one write operation to perform a = a +1.
If there are this kind of statement in a program, sometimes the AccelDSP will be hanging during generating Verilog output.
The last one is that I found I cannot announce a persistent variable with large array size. If I announce
persistent a
if isempty(a)
   a = zeros(1,204800);
end
then, again, the AccelDSP will be hanging during generating Verilog output.
Is there anyone who can tell me how to solve the last one problem ? Or, tell me how to buffer a large amount of data.
Hou-Shin
Visitor houshin
Re: A data buffering problem and some AccelDSP experience to discuss
Hi everyone,
You can write the program like
function y=fir(x)
a=3;
b=4;
if x == 0
   y = a;
else
   y = b;
end
I encountered the first problem I described is lase because of a large memory mapping as the last problem I posted.
Hou-Shin
