Observer chanyeoh
AXI-Stream to Video Out and Video In to AXI-Stream
Hello all,
I have been trying to convert the AVNET core into RGB and some video processing. However, I would like to access cores I have written before for the video out.
So, my goal is:
Avnet HDMI IN => Video In to AXI-4 Stream => Chroma Resample => YCbCr to RGB => Video4-Stream to Video out => (My Cores) => Video4-Stream to Video In => RGB to YCbCr => ...
So everything works if I do this:
Avnet HDMI IN => Video In to AXI-4 Stream => Chroma Resample => YCbCr to RGB => RGB to YCbCr => ...
However, when I added the Video4-Stream to Video out core and Video4-Stream to Video In core, things seem to fail. I am unsure why tho. The design looks like such:
Some tip and guidance is appreciated, as I'm unclear on how to solve such an issue.
Re: AXI-Stream to Video Out and Video In to AXI-Stream
Hi @chanyeoh,
How do you check that it is working in this case Avnet HDMI IN => Video In to AXI-4 Stream => Chroma Resample => YCbCr to RGB => RGB to YCbCr => ...?
And why do you say that it is not working in the other case?
What I usually check when I have issue in a video design:
-> Check the underflow/overflow signals of Video In to AXI-4 Stream
-> Add an ILA to see if there are some change on the tready and tvalid signals
Observer chanyeoh
I was able to check it when I compiled to whole project and run it. Everything ran properly.
When I check the underflow/overflow signals of Video In to AXI-4 Stream they are both 0.
When I check the ILA I do see changes from the tvalid signal. tready is always set to 1.
I have also checked the video active signals, and it turns out to be the same as the tvalid signal. However, for some reason, the video is not being shown/framing correctly.
Hi @chanyeoh,
What do you use to display the video? Do you have data at the output of the design?
Thanks and Regards,
Observer chanyeoh
On the output side, it appears to underflow, and the video is not locked. The HSync, VSync and Video Active are also not active. I wonder why is such the case.
Hi @chanyeoh,
Continu to use an ILA on the upstream blocks to understand why
Observer chanyeoh
Observer chanyeoh
I have finally manged to get some output. However, I am unable to understand the underflow. It seems to be the same width as the inactive frame. Why would such behavior happen? Does that mean I have to use VDMA?setup.png
Hi @chanyeoh,
It happens because you are running at the same frequency input and output. So each time you have data available, they are sent out directly.
Yes using a VDMA to do frame buffering can help.
Observer chanyeoh
What if I want to avoid VDMA? Is there any way to avoid it? What would happen if I ran the output frequency 0.1 MHz slower? Would it resolve the issue.
Hi @chanyeoh
Yes I guess that if your output frequency is slightly below you won't see the underflow. But I would reduce the frequency by at least 1MHz.
Hi @chanyeoh,
Any updates on this issue? Is it solved? If yes please close the thread marking it as solved.
Kind Regards,
