Adaptive Sync of the Display Port RX subsystem 2.1 for Kintex-7
Dear all,
Is Adaptive Sync supported by the macro IP?
If possible I'd like to have the some replies also for DisplayPort 1.4 RXSubsystem v1.0
Andrea
Re: Adaptive Sync of the Display Port RX subsystem 2.1 for Kintex-7
HI @andreac_avnet,
Thanks to @watari I understand that this is in the DP Spec (introduced in DP1.4).
No the Xilinx Displayport IPs do not support this (I am not sure if this can be done by modifying only the driver + application though).
If a customer require it, he can ask his FAE to discuss this with Marketing.
Hi @andreac_avnet,
Could you clarify what you call Adaptive Sync?
Scholar watari
Hi @andreac_avnet
Do you want to use "Adaptive Sync" which is defined by VESA ?
- Adaptive Sync (Free Sync by AMD)
- G-SYNC (by nVIDIA)
I'm not sure. Maybe latest IP doesn't support it.
However DP Rx IP has a potential to support it.
HI @andreac_avnet,
Dear all,
Ok, I understand.
Thank you both@florentw and @watari for the help.
Andrea
Dear @watari and @florentw,
Do you know if it's supported for DisplayPort 1.4 RXSubsystem v1.0 ?
Our customer doesn't has the VESA standards, but on their site I found this link:
https://vesa.org/featured-articles/vesa-adds-adaptive-sync-to-popular-displayport-video-standard/
which shows that they added the Adaptive Sync to the 1.2a standard.
Andrea
HI @andreac_avnet,
No, as mentioned, as of now, it is not supported by Xilinx IPs
Perfect.
Thank you for the resolution.
Best regards.
Andrea
