Participant hariprasadb
Audio Formatter in Vivado 2018.3
I was referring to https://japan.xilinx.com/support/documentation/ip_documentation/audio_formatter/v1_0/pg330-audio-formatter.pdf Audio formatter user manual and Table 1 : Supported Data Formats In Memory
I want to know what is the information carried by AES [7:4] and AES[3:0] fields ?
Does it mean AES[3:0] = preamble and AES [7:4] = {Parity, Channel Status Bit, User Data Bit, Validity Bit } ?
With Regards,
Hariprasad Bhat
Tags (2)
Re: Audio Formatter in Vivado 2018.3
Hi @hariprasadb,
Yes you are correct. You might want to refer to PG045 for a better view of the mapping on the AXI4-Stream interface for AES:
Best Regards,
Florent
Hi @hariprasadb,
Best Regards,
Florent
Hi @hariprasadb,
Happy New Year 2019!
Is everything clear for you on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
