Visitor srui
Bi-directional pins: how to configure them in system generator?
Hi all,
I want to use a set of FPGA pins as bi-directional I/Os together with System Generator. How can I do this? How do I configure my target hardware for this?
Best regards,
Sergio Rui Silva
Re: Bi-directional pins: how to configure them in system generator?
bi-directional Gateways are not currently availble in System Generator.  Inputs and outputs should be treated seperately and once the HDL is generated a bi-directional port can be created at the top level to route these through a single IO.  Take a look at answer record 15505 for more details:
http://www.xilinx.com/xlnx/xil_ans_display.jsp?getPagePath=15505
Another possibility is to attempt to bring in a bi-directional IO buffer with an HDL black box, however the former is the recommended flow.
Visitor blende64
Hi jeffreyh,
I have the same Problem, but please give me a detailed, beginner-friendly explanation of howto "bring in a bi-directional IO buffer with an HDL black box" . Which files need to be changed? and how?
(EDK 8.1i)
Thank you
Visitor r_a_c_a_4_u
i have a similar problem .... but i want to change the sample time of my output of black box... how should i do it ?....
