CSI2-RX Subsystem IO PIns
Hi Folks,
In our design we have a camera sending CSI2 data over FMC. We use a ZU5EV in which we planned to use the LogiCORE CSI2-RX subsystem.
When configuring the IP core, it looks like the Clock IO pin which is on a GC IO pin (D4) is not allowed to be used. Is this a limitation of the IP core MIPI DPHY?
How can we work around this?
Re: CSI2-RX Subsystem IO PIns
HI @ziladdev,
Do you have any updates on this? Were the replies from @karnanl and @bpatil enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Hi @ziladdev
Provide FPGA Device part no. and FPGA bank details (which you want interface with MIPI CSI-2 RX).
Provide Vivado version details.
How many MIPI CSI-2 instance and data lanes you intend to use?
Bhushan
Bhushan
FPGA: xczcu5ev-sfvc784-1-e
IO Bank : 66.
Vivado version: 2018.2
CSI-2 RX instances : #1 (now), will be extended to 4 cameras later.
num-lanes: #4
io_pins.pngio pins
Hi @ziladdev
The MIPI D-PHY IP core implements a D-PHY RX interface and provides PHY protocol layer support compatible with the MIPI CSI-2 RX interface (Check block diagram below). PG202 April 4, 2018 defines Pin and Bank Rules for MIPI DPHY in Appendix C.
As per PG202, RX clock lane pins must be DBC, QBC and GC_QBC pins.
D4 is not DBC, QBC and GC_QBC pin ( Check https://www.xilinx.com/support/packagefiles/zuppackages/xczu5evsfvc784pkg.txt for more details).
That's why you are not able to use D4 as clock IO pin for MIPI CSI-2 RX.
I will recommend to go through PG202 April 4, 2018: Appendix C to understand pin assignment of MIPI DPHY RX.
Bhushan
Bhushan
Patil,
I am aware of those, however the pins delivering clk and data lanes are fixed by hardware...
is there any potential work-around that doesn't involve redesigning the hardware to get the pins match....
Hi @ziladdev
As per my knowledge, there is no work-around for using non-clock pins for clock of MIPI CSI-2 RX.
Do you have access for only one bank pins for MIPI Camera's on FMC interface? or there is possibility of other HP bank pins can be available for MIPI CSI-2 RX Interface on FMC interface?
Does all MIPI CSI-2 RX instances running at same speed?
Bhushan
Bhushan
GC is still a clock pin. I think the question really is, should we change the hardware as the pins seem to be fixed and do not match the ultrascale way of handling DPHY or is it a limitation of the IP core itself and we could perhaps find another IP core that can do the work.
@karnanl and @florentw Can you please comment on this issue?
Bhushan
Hello @ziladdev
As mentioned by Bhushan  @bpatil  in previous post, MIPI CSI-2 RX/D-PHY shall use DBC/QBC pin for clock pin, you cannot use GC pin. This is device limitation. (Please see PG202 appendix C).
I think you will need to fix your board to use Xilinx MIPI IP.
There is 3rd party MIPI IP available (from NWL for example), but I believe this IP also using Xilinx MIPI D-PHY IP as a PHY IP so you will have the same restriction.
Thanks & regards
Leo
HI @ziladdev,
Thanks and Regards,
Florent
