Camera Link to SDI convertion
I must implement a Camera Link to SDI convertor in Artix7. Has somebody any idea what is the best way to do that?
Thanks for your help.
Farzad
Tags (2)
Re: Camera Link to SDI convertion
Hi farzad.hosseini@ruag.com,
Yes xapp585 and xapp1097 are the one you should use for reference. But you are still required to do your own bridge between  the input and output. I do not think there is any example of this. You need to create your own logic
Florent
You need to create a bridge to convert the signals from Camera Link to SDI, then you can use the SDI IP.
Florent
Dear Florent,
 thanks for your reply.
Yes, the issue is the bridge. I need more details.
Can I use the High Speed SelectIO Wizard or use XAPP585?
Are there any application notes, which could be helpful for beginners?
Farzad
Florent
HI farzad.hosseini@ruag.com,
Do you have any updates on this?
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Florent
