Mentor
Mentor
Can I use BBRAM and eFUSE as a storage of HDCP key ?
Hi all
I'm investigating a capabirity of BBRAM and eFUSE for secure key storage.
Especially, I hope to use BBRAM and eFUSE as a storage of HDCP key.
If yes, how do I connect it to encode and/or decode video data with HDCP key ?
Best regards,
Re: Can I use BBRAM and eFUSE as a storage of HDCP key ?
Hi @watari,
I am hesitant to say that this is possible as it is not a use-case I have looked at before.
If you are using the BBRAM/eFUSE, the intended use-case is really to put the KEY in the bitstream and then use the BBRAM/eFUSE to encrypt the bitstream.
2018-11-02 10_49_49-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
Take a look at PG224. HDCP 1.x v1.0
Sam
Xilinx Video Design Hub
Hi @watari,
Sam
Mentor
Mentor
