Visitor yyq1994
Can Ultrascale+ MPSoc encode different resolution streams with one video in simultaneously?
Hello! I want to know if can I use Ultrascale EV to encode one video to three different resolution h265 streams simultaneously? For example, the video input is 4K, I want to get 4K@60fps, 1080P@30fps and 640x480@30fps simultaneously. Can I realize this with Xilinx MPSoc? It will helps me a lot.
Thanks for any answer.
Re: Can Ultrascale+ MPSoc encode different resolution streams with one video in simultaneously?
Hi @yyq1994
[Florent] - Yes you can encode up to 8 different stream simultaneously if the total of the streams is in the 4K60 bandwidth
[Florent] - So no this case is not possible because your total BW will be over 4K60. However you could do 4K@30 + 1080p30 + 640x480@30
In summary: The Zynq Ultrascale+ MPSoC VCU can encode up to 8 simulataneous video stream as long as the total bandwidth for all the streams is in 4K@60.
Hi @yyq1994
Visitor yyq1994
I know. Thank you very much!
HI @yyq1994
If everything is clear for you, please kindly mark the reply which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Observer elahi
But in the VCU ipcore, the minimum supported resolution is 1280x720, so we cant encode in 640x480. Am I right?
Hi @elahi,
1. Please do not post on someone else's topic. Please create a new topic when you have a question
2. Yes you can encode 640x480 streams
3. I am closing this topic as it is already solved.
