Visitor videophile
Cannot build video sample code for TB-FMCH-HDMI4K with QUATTRO?
There is no information available to help us to build the sample code to check the video path in the QUATTRO board using TB-FMCH-HDMI4K card.
According to the tx manual (attached) page 61, the TB-FMCH-HDMI4K board and the HDMI subsystem are supported in some boards: KC705/KCU105/ZC706/VCU118 but not the QUATTRO. Therefore we cannot do the build using the sample code from the Vivado design tool/subsystem. It does not list the QUATTRO as one of the target FPGA to do the build. Anyone out there has a solution for this!
Re: Cannot build video sample code for TB-FMCH-HDMI4K with QUATTRO?
Hello @videophile
I believe you are using ACDC Quattro Kintex UltraScale Development Platform. IP example design for HDMI RX/TX is provided for Xilinx specific platform. If you are using other platform then you need customize this example design according to your custom board.
You should go through IP example design targeted for KCU105 and modify this design according to your board.
Bhushan
Hello @videophile
Bhushan
