Cordic
Good day:
How I can use the Logicore Cordic for sin o cos signals, thanks.
Post: I´ve the xilinx 8.1i and xilinx 9.2, thanks
Re: Cordic
Bryan,
The CORDIC core can rotate a unit vector by input angle theta to produce an output vector sin(theta), cos(theta). This is described in more detail in this core's datasheet.
Are you simply trying to produce sin/cos waveforms? If that is the case, I would recommend you take a look at the Sine-Consine Look-up Table (Digital Signal Processing -> Trig Functions) or DDS Compiler/Direct Digital Synthesizer (Digital Signal Processing -> Waveform Synthesis) cores.
Cheers,
bt
