Visitor aubogdan
DP Sink Core with 2x lane and Native video interface
I simulate DP Sink Core with 2 lanes and connect it with my TX DP controller.
I am trying to transfer next image in 1x and 2x lanes: 640×480×75Hz, RGB 8/24, STREAM_clk is 31.5 MHz, LS_clk is 162 MHz.
In the 1x  everything is OK.
But in the 2x on the output video interface I see strange picture on the waveform:
Within the output of one line, I see moments when rx_vid_enable signal becomes inactive for one clock cycle.
I attached this picture.
What is the reason for this signal behavior ?
Is this a possible FIFO overflow due to too slow stream clock?
Thank you.
Re: DP Sink Core with 2x lane and Native video interface
HI @aubogdan
Are you using the Xilinx Displayport Rx subsystem or Displayport 1.4 RX subsystem?
Fifo overflow might be a root cause but I would say this is the opposite. Your video clock is slightly over the pixel clock so the core is compensationg toogling the data_enable signal.
The way to tell if you had a FIFO overflow is by looking at the register values
Note that for most cases, the core expect to be in a frame buffer use case (you have a VDMA or video frame buffer connected after the core) with the video clock over the pixel clock.
If you want to use the core in non-frame buffer use case, it requires you to use an extenal clock which can meet the requirement of the DP standard. Refer to pg233:
HI @aubogdan
Visitor aubogdan
Hi, @florentw !
Thank you for answer.
I use Xilinx DisplayPort v7.0 and configure it as Sink Core.
Am I right understand next things:
— that for 1x mode when I use the core in the non-frame mode the frequency ratio between video and pixel clock is equal 1, so I can see my picture on the RX side.
— But when I switch to 2x mode I need use clock from external PLL for video clock, according  the requirement of the DP standard ?
HI @aubogdan
Please note that the LOGICORE DIsplayport IP is a discontinued IP.
Then I am not sure about what more you are taling about. If this is about the clock mode in reg 0x528, no this is not correct. The clock mode is set by TX but the RX core is not using it.
Whatever if the clock is in sync or async mode, the behaviour will be the same. If you do not have any buffer, the clock need to exactly match the pixel clock. If you have a frame buffer, you can set a faster clock (because you recreate the pixel clock + data later).
Visitor aubogdan
Hi @florentw !
I attached my clock scheme.
The pixel clock is the same for the TX and RX parts.
I don’t understand why it works in 1x mode, but not in 2x mode?
Hi @aubogdan
Again I do not understand what mode you are talking about. Please clarify.
Is it how many lanes are trained?
Visitor aubogdan
@florentw
2 lanes are trained.
The values from DCPD for Xilinx RX:
00001h - 06h (1.62 Gbps)
00002h - 2h (Two lanes)
I transfer the same image in 1x mode (I configured all system in 1 lane) - it works.
I do not understand why it is not work in 2x mode. The image and its parameters are the same as for 1x : 640×480×75Hz.
I hope you understand my question.
Thank you.
Scholar watari
Hi @aubogdan
What kind of DP source device do you use ?
It depends on the result of negotiation between source and sink devices and architecture of graphics card's driver.
HI @aubogdan
When moving to 2 lanes you need to make sure that all the parameters of the timing are dividable by 2. Also the pixel clock is divided by 2. You need to make sure you have the correct precision.
Visitor aubogdan
Hi @florentw.
The input image is coming to TX part with the 35 MHz for the pixel clocks. If I divide it by 2, I'll have 17.5 MHz. But in the data sheet (page 11, PG064 November 30, 2016) I see that the minimum for the vid_clk is 25 MHz.
I am trying to do next:
1. Transfer the image, which really need 2x mode.
2. Use frame buffer for the Rx native video interface.
I return with the Results.
