Participant urvish@htic
Detection of s_axis_video_Tuser_SOF Early and Late
Hello!
I want to write a "counter less" logic for detection of early and late of s_axis_video_tuser_SOF signal. Please suggest me a good logic.
Best Regards,
Urvish
Re: Detection of s_axis_video_Tuser_SOF Early and Late
Hi urvish@htic,
Are you so stress about ressources that you need to avoid counters? Counters are not consumming really much of ressources... Not sure if you will be able to save a lot with another way. At lest I am not sure about the time you would spend, if it really worth.
Florent
Hello urvish@htic,
You want a "counter less" logic for detection of early and late of s_axis_video_tuser_SOF signal?
Well the solution I see is to invoke black magic ;)
(I do not see any solution without a counter)
Florent
Scholar watari
Hi urvish@htic
The best way it to implement like PLL or DDS in your device. (Especially phase detector.)
However it is difficult to implement it in FPGA.
Best regards,
Hi @watari,
This could be a good idea but I am not sure if you would be able to detect a shift of 1 pixel clock
Florent
Scholar watari
Hi @florentw
This solution is similar ADC to generate pixel clock from HSYNC and/or VSYNC...
Best regards,
Hi urvish@htic,
Were you able to try watari's solution?
If not, what are your requirements besides "counterless"? What is the issue that you are trying to solve? How does it happen? There may be a better way to solve your problem.
Sam
Xilinx Video Design Hub
Hi @samk,
I have a image frame coming in RGB24 format and 1 pixell per clock. I have to write a module for finding if the SOF flag is early or late. Because this is a quite simple problem to handle with counters, I want to know if there extits any logic to do the same without using counters and thus minimize the resource count.
Urvish
Best Regards,
Urvish
Hi urvish@htic,
Florent
