Diplay Port RX subsystem 2.1 for Kintex-7
Does the DP RX Subsystem 2.1 works fine at 120 fps in stereo video mode with resolution 1600x1200 for each stream ?
(2 streams so 240 fps)
The DP support 1.2a standard but the document about the Display Port doesn't talk about the support of 3D clearly.
Where does the 2nd stream will be presented on ? on AXI4S Video Str2 ?
Furthermore I would also need to know if switching from mono to stereo is dynamic.
Best regards,
Andrea
Re: Diplay Port RX subsystem 2.1 for Kintex-7
Hi @andreac_avnet,
I didn't answer because I thought they were related to 3D...
Yes in the case of MST
This is related to 3D which is not supported.
Florent
HI @andreac_avnet,
Theoretically, the DP IP should support 2 streams 1600x1200@120Hz (in MST) as it is in DP10.2 bandwidth
However, I do not think the DP Subsystem IP does not support 3D. In the DP spec, 3D is done on in-band stereo and this is not supported by the core:
Florent
Dear @florentw,
Thanks so much for your fast reply.
But you didn't ask those 2 questions:
Can you give me and answer ?
Best regards,
Andrea
Hi @andreac_avnet,
Florent
Hi @florentw,
Thanks for your help.
Best regards,
Andrea
