Re: Display Port TX Design requirements
HI @vinay_shenoy,
Xilinx does not support converters. It is up to the user to make sure that the adapter can work with their project.
On you monitor can you make sure you enabled the ULTRA HD deep colour:
Florent
Hi @florentw,
Yes, In the monitor I've enabled the ULTRA HD deep colour.
Is it possible to share the ZCU102 DP TX only project with which you were able to get UHD @60fps?
I want to check the application.
Vinay Shenoy
Vinay Shenoy
Scholar watari
Hi @vinay_shenoy
As you already knew, DP Tx on PS side can not support 4K@60Hz. The limitation is 4K@30Hz.
However, if you implement DP Tx with Xilinx's IP, you can use 4K@60Hz.
Best regards,
Hi @watari,
I'm working with DP TX using Xilinx IP (PL based design) and I am not able get UHD @60fps. I see display only upto UHD @30fps.
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
I used the example designs integrated in vivado + sdk. Nothing more.
Please try with the DP 4K monitor instead of using an adapter.
Best Regards,
Florent
Hi @florentw,
Thank you for the support.
I don't have a 4K DP monitor here. Let me check if I can arrange any.
Vinay Shenoy
Vinay Shenoy
Scholar watari
Hi @vinay_shenoy
Can you show us detail information for active adopter and cable (of cause cable length), if you can not prepare DP 4K monitor ?
Or
Can you show latest DPCD value again ?
I suspect an adopter and/or quality of cable...
PS.
I'M sure that the best way is to use 4K DP monitor.
But I can understand a little...
Best regards,
Hi @vinay_shenoy,
Do you have any updates on this? Were you able to get a DP monitor? Did you do more tests?
Thanks and Regards,
Florent
Hi @florentw,
I have got the TED FMC card and a new Display Port 1.2 Monitor  to test the Xilinx example design at UHD@60fps.
In the PG199, page number 106, its mentioned "To run the example design on the ZCU102 board, ensure that the FMC voltage is set to 1.8V using SCUI Tool".
Where can I get SCUI tool?
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
On the ZCU102 page:
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0048-zcu102-evaluation-kit-hub.html
Under example design:
Florent
HI @vinay_shenoy,
Are you finally able to do 4K@60 (with reduced bandwidth) now?
Florent
Hi @florentw,
Sorry for the delayed response.
Yes, I was successful in testing the DP TX only example design at 4K@60 with new DP monitor.
Vinay Shenoy
Vinay Shenoy
Hi @vinay_shenoy,
As it is now solved for you, could you kindly close the topic by marking the best reply as accepted solution?
Thanks and Regards,
Florent
