Display port Error in QuestaSim
Hi i have generated display port ip example from Vivado v2019.1 ,compiled succesfully but in elaboration i am facing below error
"-- Loading module dp_ss_wrapper
-- Loading module unisims_ver.IOBUF
** Error: ../../../../dp_tx_subsystem_0_ex.srcs/sources_1/bd/dp_ss/hdl/dp_ss_wrapper.v(223): Module 'dp_ss' is not defined.
-- Loading module glbl
Optimization failed"
DARSHAN
Re: Display port Error in QuestaSim
HI darshan.kumar.k.a@continental-corporation.com
Kindly note that simulation for the Displayport TX Subsystem is not supported.
Florent
Hi Florent ,
                    I   am not only doing simulation for the Displayport TX Subsystem .Please find the complete example of Block design.But compilation done successfuly during elaboration giving the Error.
DARSHAN
Hi darshan.kumar.k.a@continental-corporation.com
Can you share the synthesis log?
Florent
Hi Florentw, please find the attached log.
DARSHAN
I am confused. You said that you were getting errors. But looking at your log file, the simulation completes with no error:
335 Infos, 116 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
Coud you clarify what error you are getting (outside simulation)?
Florent
Hi Florentw ,
                     I am doing simulation in questa sim .compilation is error free only during elaboration it is giving error .can you help me in resolving this .
DARSHAN
As mentioned in my first reply, simulation is not supported with the Displayport Subsystem IPs.Thus, no, I cannot help you with this as I do not have any working test bench and I am not even sure this will work.
You might want to avoid doing simulation with the Displayport Subsystems IPs
Florent
