Visitor divya2m
Display port configuration using microblaze
while working on a project having DP Tx subsystem, microblaze, BRAM,clocking wizard, and reset.synthesis , implementation and bitstream were generated. and exported to SDK. corresponding BSP was also generated. the generated 'c' code has certain values like (0x234) as offset address in certain 'c' functions declared. these offset addresses do not match with the offset address of the DP or VPHY registers. could you please throw some light on what these offset values correspond to??. and how should the registers be accessed through this 'c' code.
thanks in advance
divya
Visitor divya2m
Re: Display port configuration using microblaze
it helped as a solution
Scholar watari
Hi @divya2m
If my understanding is correct, it show offset address of DPCD...
Best regards,
Hello @divya2m ,
As watari mentioned, 0x234 is the DPCD register on the DisplayPort.  If you want to know in details, please get the specification for the VESA DisplayPort Standard.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
Visitor divya2m
