DisplayPort RX Subsystem v2.1 PG233
Dear All,
About the DisplayPort RX Subsystem v2.1 PG233 page 59:
"RECOMMENDED: The Xilinx MMCM is not accurate enough to be used to regenerate the necessary clock
for non-frame buffer design. You need to use an external PLL that meets the requirements of the
DisplayPort Standard. See section 2.2.3 of the DisplayPort Standard v1.2a [Ref 9] for more details."
Can I have some more Infos about the external PLL ?
Because one of my customer want to use the external PLL but there are no specs.
Thanks in advance.
Andrea
Re: DisplayPort RX Subsystem v2.1 PG233
Hi @andreac_avnet,
As mentioned in the Product Guide, the XIlinx implemented solution is the solution with the frame buffer. The only guidance we can provide is to follow the displayport spec for the clock. We do not have a specific reference for a PLL clock.
Apart form that, the 3 possible solutions look correct.
Scholar watari
Hi @andreac_avnet
I'm not sure. But in this case, a design without frame buffer requests strictly native video clock.
Because of frame buffer works as cushioning for different clock frequency.
However, there is not in non-frame buffer design.
So, it depends on your target resolution and FIFO length like called the line buffer.
Dear @watari,
thanks for your reply.
Requested Resolution: we have to support the following two modes:
3200x1200 @120Hz sRGB
3200x1200 @60Hz sRGB
Customer said:
"About the FIFO length: we'd like to receive indications from Xilinx on this point.
What we have understood is that, considering the without-framebuffer mode, we could choose one of the 3 following implementations, to overcome
and manage the asynchronism between source &synch devices connected via DP:
1) use a high-precision 24-bit PLL
2) use a lower precision (< 24-bit) PLL, together with a "small" FIFO with adaptive blanking to "absorb" and manage the source variations
3) do not use any PLL but put a big FIFO with adaptive blanking to "absorb" and manage the source variations
We 'd like to have instructions from Xilinx to correctly decide on component dimensions: in particular on scenario 1 we'd like to know which specific PLL with 24-bit precision we could use."
Andrea
Hi @andreac_avnet,
Scholar watari
Hi @andreac_avnet
As @florentw already mentioned, I agree his suggestion.
If you only support the following resolutions. I think that it is easy. (Not need too big FIFO.)
- 3200x1200@120Hz
- 3200x1200@60Hz
Dear @watari and @florentw,
Thanks both of you for the help.
Andrea
