DisplayPort RX example design path length error windows 10
    I would like to report a bug where in Windows 10 in Vivado 2017.4 where I am trying to open up the DisplayPort RX Example design, the design opens and the TCL execution begins and the block diagram starts getting built, but I get a path length error shown below.   I did put this in my root directory E:\ so I know there is no way I can make the path length shorter.
   Is there any way to make this work in Windows, or do I need to generate first in Linux (which I currenly do not have this option)?
Tim
Re: DisplayPort RX example design path length error windows 10
@florentw,
   This worked for me:
1. When error occurred I clicked OK which automatically closed the example design project.
2. Open a new Vivado instance and open the generated project and did a file-save-as, and named the project a.
3. With the opened project now named "a", I opened the block design.  I also created a new block design and called it f and copied all from the existing block design and pasted into the new block design f.
4. I renamed the 4 sub-hierarchies to b c d and e.
5. I deleted the existing block design and kept only the f block desing.
6. for "f" I created an hdl wrapper and generated output products, and that seemed to work and is now synthesizing for me currently.
Tim
Hi @tim_severance,
This is not a bug but a known limitation of Vivado (and the DP exdes) on windows ;-)
I am already working with development to improve this.
Anyway, the workaround is to generate the example design on windows, have it fail and then save project as with a really short name (proj_1). This should work.
Some other workaround might be to reduce the name of the IP instance in the BD before generating the example design
@florentw,
   Thanks for the quick reply!
   So if I save the file with a really short name (I can call it "a" for example), how to I get it to resolve the errors?
   I was wondering if I should edit the tcl file that gets sourced to name the project "a", but I am not sure which tcl file is getting executed.
Tim
Hi @tim_severance,
If you do save as and you regenerate the output products, it should work.
Modifying the generated tcl is another option (it is the method I used but I prefer sharing the other one on the forums as it is easier for novices).
regards,
@florentw,
    I tried the save-as and used "a" as the name, but I am getting the same errors when I generate output products.
    I wonder if I need to also rename the block design and also the hierarchical block names.   Do you know how to rename a block design?
Tim
Hi @tim_severance,
Note that I have not tested the save as method. This is coming from this topic and it seems to work:
https://forums.xilinx.com/t5/Video/Video-Phy-Controller-DRP-won-t-return-DRP-ready/m-p/828548/highlight/true#M18764
As per the topic you might need to do "save bd as" as well
But if you know where the tcl is, you can easily reduce the names and it might be easier (I have tested this method)
@florentw,
   This worked for me:
Tim
@florentw,
   Once I have the bitstream generated and launch SDK, how do I generate the example design?   I tried doing the Import Examples next to the c_dp_rx_subsystem_0 (see image below), but it din't seem to generate a "main" function.
Tim
Hi @tim_severance,
It should generate a main into a xdprxss_rxonly.c file.
@florentw,
   Yes, I see that, thanks.   I was able to get it up and running eventually.
Tim
@florentw,
   I found the following page that shows how to setup Windows to accept long path names, so I set this up, but Vivado still complains.   Is there a way to tell Vivado that Windows will actually accept the path lenght?   If not, can this please be added as a feature request?
https://www.howtogeek.com/266621/how-to-make-windows-10-accept-file-paths-over-260-characters/
Tim
Hi @tim_severance,
I will discuss this with development.
@florentw,
   Do you know if I setup the project using core container for the block design IP if that would prevent all the long paths in the sources subdirectory?   I think that is where most of the long path names are.
Tim
Hi @tim_severance,
I am not 100% sure but yes, core container might help with the path length
@florentw,
   Any update by chance on these path length errors?   I wanted to generate the DisplayPort RxTx example design in Vivado 2018.2 but after starting the example project generation I forgot that this is not possible in Windows due to path lengths.  I already have the project in "C:\" to minimize the path length.
   It would be great if this project could be rebuilt to make sure it works in Windows 10.
Thanks!
Tim
Do the following:
When you generate the displayport subsystem example design, the block design should be opened.
  1. In the tcl console enter the command (<path> is the path to a known directory)
    write_bd_tcl <path>/bd.tcl
  2. Open this bd.tcl file generated with a test editor
  3. Find the following line:
    # CHANGE DESIGN NAME HERE
    variable design_name
    set design_name dp_rx_subsystem_0_design_synth
  4. Change to
    set design_name dp_ss
  5. Create a new project with a short name (ex dp_ss) in directory close to the root directory
  6. Source the bd.tcl file from the tcl console
    source bd.tcl
Hope that helps,
@kka,
   That *almost* worked!   After generating the wrapper and implementing it failed bitstream generation with the errors below.   I am not sure why these IOSTANDARDs did not get defined.
Tim
HI @tim_severance,
There is a xdc added in the initial project. You need to add it to the new project as well.
You will find it in the import folder in the example design folder.
@florentw / @kka,
   Thanks for the information, I was able to implement successfully!
Tim
