DisplayPort TX DPCD State Machine bug?
I am using the DisplayPort TX block example design in Vivado/SDK 2018.1 which I am plugging into a custom DP Receiver chip which our company designs and I am monitoring the DPCD communication using a Unigraf DPA-400 auxiliary channel analyzer.
It seems the training sequence which is controlled by the Xilinx DPCD master (DP Source) doesn't follow the protocol mentioned in the VESA DisplayPort Standard documentation.   The KC-705 DP Source seems to start the clock-recovery phase of training just fine, and then reads back from the DP Rx if CR_DONE=1 which our chip does respond just fine, but the KC-705 DP source never stops that portion of the training and moves on the the EQ portion of the training (TPS2/3/4).
Is there possibly a bug in the current implementation?
If you would like more details we can take this into a private conversation.   But I am suspecting there is a bug in the current implementation of the DP Tx DPCD state machine.
Vivado/SDK Version used: 2018.1
dp_tx_subsystem (in block design): 2.1 (rev. 2)
dp_v7_0 used in BSP
dptxss_v6_0 used in BSP
Tim
Re: DisplayPort TX DPCD State Machine bug?
DPCD Sequence experienced with (KC-705 -> DP Tx -> our Custom DP rx chip):
KC705: Sets 4 lanes 5.4Gbps
KC705: Initiates training using TRAINING_PATTERN_SET=1
KC705: Request training status
   Custom DP RX: Reports LANEX_CR_DONE=1 for all lanes
KC705: keeps doing this 5 times
KC705: Stops training by setting TRAINING_PATTERN_SET=0
KC705: Sets 4 lanes 2.7Gbps
Wheras when I plug the KC705 DP Tx into a Lilliput DP monitor:
As soon as the monitor returns LANEX_CR_DONE=1 the KC705 DP TX changes TRAINING_PATTERN_SET to 3.
Why would this not occur on the custom DP Rx?   Would it be some kind of a timing problem?   Any insight here would be very helpful.
Tim
Scholar watari
Hi @tim_severance
According to your DP sequence information, it seems signal integlity issue between two chips or clock recovery issue which include reference clock jitter.
Would you make sure them ?
Also I recommend to check PLL lock status and symbol and disparity errors in the Sink through DPCD registers.
Would you refer the following document on page 114 and 115, if you need more detail ?
https://www.xilinx.com/support/documentation/ip_documentation/dp_tx_subsystem/v2_1/pg199-displayport-tx-subsystem.pdf
Best regards,
@watari,
   Thanks for the response.
   I do not believe it to be a signal integrity issue due to the fact that if I unplug the DP cable from the KC705 DP Tx source and plug instead into our own DP Tx solution then everything works and if I watch the AUX analyzer it works correctly where the DP RX gets clock recovery and then the DP TX moves on the further training.
   Also, if I use the same DP cable and plug the KC705 DP TX into a monitor and watch the DP AUX, then that seems to work fine as well.
   So it seems to be some interaction between the KC705 DP TX and our custom DP RX and our DP RX reports clock recovery success, so why doesn't the DP TX stop the training at that point and move forward with starting TPS2 or TPS3?   That is simple logic and should have nothing to do with signal integrity as far as I can tell.
   So I guess what I am looking for is for somebody to look through the DP TX AUX state machine and see if there is any way it can get clock recovery success and *not* move forward with further training.
Tim
If somebody takes this offline I can share my AUX analyzer logs.
Tim
Hi @tim_severance,
Please share your AUX log via email. I will have a look next week.
Florent
@florentw, Thank you, I just sent you an email with all the details.
Tim
Hi @tim_severance,
Do you have any updates on this.
Just for some detail of our offline chat.
I agree that there is something wrong in the training. I suggested to try with a GPU to see what you get. It could also be a good reference if the training succeed with it.
Thanks and Regards,
Florent
