Visitor karen
DisplayPort: no picture on ZCU102
  I'm trying to run the tricube application on a Linux and viewing the result on the display port.
  ( ug1209-embedded-design-tutorial.pdf)
  however, i can't see a tricube on the display port only black screen shown.
  and the following message appears "Entering power save mode. (used dell u2711 monitor)
  Could you let mo know the solution?
root@plnx_aarch64:~# cp /run/media/mmcblk0p1/tricube /tmp
root@plnx_aarch64:~# export DISPLAY=:0.0
root@plnx_aarch64:~# /usr/bin/Xorg -depth 16&
[1] 2012
X.Org X Server 1.18.0
Release Date: 2015-11-09
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.10.0-327.el7.x86_64 x86_64
Current Operating System: Linux plnx_aarch64 4.6.0-xilinx #1 SMP Tue Feb 7 10:58:38 IST 2017 aarch64
Kernel command line: earlycon=cdns,mmio,0xFF000000,115200n8
Build Date: 23 January 2017  02:32:35PM
Current version of pixman: 0.32.8
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 13 05:31:54 2017
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
root@plnx_aarch64:~# /tmp/tricube
Start Main
Calling OpenDisplay
Calling XCreateSimpleWindow
Calling XStoreName
Calling XMapWindow
Calling prepareGraphics
Calling eglGetDisplay
Display Used 0x1 & EGL versions are 1.4
Your EGL Version is "1.4 Linux-r5p1-01rel0"
Your EGL Vendor is "ARM"
Calling doGraphics
iLocPosition = 0
iLocColor   = 1
iLocMVP = 0
Scholar watari
Re: DisplayPort: no picture on ZCU102
Hi @karen
It seems that DisplayPort Tx goes to "Power Save mode" from "Normal mode" by no-signal.
Could you show me "Xorg.0.log" and "xorg.cong" file ?
Thank you.
Best regards,
Visitor karen
xorg.cong
Section "InputDevice"
        Identifier      "System Mouse"
        Driver          "mouse"
        Option          "Device" "/dev/input/mouse0"
EndSection
        Identifier      "System Keyboard"
        Driver          "kbd"
        Option          "Device" "/dev/input/event0"
EndSection
Section "Device"
        Identifier      "ZynqMP"
        Driver          "armsoc"
        Option          "DRI2"                  "true"
        Option          "DRI2_PAGE_FLIP"        "false"
        Option          "DRI2_WAIT_VSYNC"       "true"
        Option          "SWcursorLCD"           "false"
        Option          "DEBUG"                 "false"
EndSection
Section "Screen"
        Identifier      "DefaultScreen"
        Device          "ZynqMP"
        DefaultDepth    16
EndSection
Scholar watari
Hi @karen
I suspect wrong setting is " DefaultDepth" as 16 in xorg.conf.
However, I'd like to confirm log file.
So, would you show me xorg.log file like "Xorg.0.log" in /var/log/ ?
Thank you.
Best regards,
Visitor karen
Hi @watari
 Xorg.0.log
[345323.044]
[345323.044] X Protocol Version 11, Revision 0
[345323.044] Build Operating System: Linux 3.10.0-327.el7.x86_64 x86_64
[345323.044] Current Operating System: Linux plnx_aarch64 4.6.0-xilinx #1 SMP Tue Feb 7 10:58:38 IST 2017 aarch64
[345323.044] Kernel command line: earlycon=cdns,mmio,0xFF000000,115200n8
[345323.044] Build Date: 23 January 2017  02:32:35PM
[345323.044]
[345323.044] Current version of pixman: 0.32.8
[345323.044]    Before reporting problems, check http://wiki.x.org
[345323.044] Markers: (--) probed, (**) from config file, (==) default setting,
[345323.044] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 13 07:14:03 2017
[345323.044] (==) Using config file: "/etc/X11/xorg.conf"
[345323.044] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[345323.045] (==) No Layout section.  Using the first Screen section.
[345323.045] (**) |-->Screen "DefaultScreen" (0)
[345323.045] (**) |   |-->Monitor "<default monitor>"
[345323.045] (**) |   |-->Device "ZynqMP"
[345323.045] (==) No monitor specified for screen "DefaultScreen".
        Using a default monitor configuration.
[345323.045] (==) Automatically adding devices
[345323.045] (==) Automatically enabling devices
[345323.045] (==) Automatically adding GPU devices
[345323.045] (==) Max clients allowed: 256, resource mask: 0x1fffff
[345323.045] (WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
[345323.045]    Entry deleted from font path.
[345323.045] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[345323.045] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[345323.045] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[345323.045] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[345323.045] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[345323.045] (==) FontPath set to:
[345323.045] (==) ModulePath set to "/usr/lib/xorg/modules"
[345323.045] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[345323.045] (II) Loader magic: 0x5b5640
[345323.045] (II) Module ABI versions:
[345323.046]    X.Org ANSI C Emulation: 0.4
[345323.046]    X.Org Video Driver: 20.0
[345323.046]    X.Org XInput driver : 22.1
[345323.046]    X.Org Server Extension : 9.0
[345323.046] (II) xfree86: Adding drm device (/dev/dri/card0)
[345323.046] (II) no primary bus or device found
[345323.046]    falling back to /sys/devices/platform/amba/amba:xilinx_drm/drm/card0
[345323.046] (II) LoadModule: "glx"
[345323.047] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[345323.052] (II) Module glx: vendor="X.Org Foundation"
[345323.052]    compiled for 1.18.0, module version = 1.0.0
[345323.052]    ABI class: X.Org Server Extension, version 9.0
[345323.052] (==) AIGLX enabled
[345323.052] (II) LoadModule: "armsoc"
[345323.052] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[345323.052] (II) Module armsoc: vendor="X.Org Foundation"
[345323.052]    compiled for 1.18.0, module version = 1.1.0
[345323.052]    Module class: X.Org Video Driver
[345323.052]    ABI class: X.Org Video Driver, version 20.0
[345323.052] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[345323.052] (--) using VT number 3
[345323.066] (WW) Falling back to old probe method for armsoc
[345323.066] (II) No BusID or DriverName specified - opening /dev/dri/card0
[345323.066] (II) Got BusID
[345323.066] (II) Opened DRM
[345323.066] (II)    DeviceName is [/dev/dri/card0]
[345323.066] (II)    bus_id is []
[345323.066] (II)    DriverName is [xilinx_drm]
[345323.066] (II)    version is [1.0.0]
[345323.066] (II) Screen:0,  CRTC:-1
[345323.067] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[345323.067] (II) ARMSOC(0): Creating default Display subsection in Screen section
        "DefaultScreen" for depth/fbbpp 16/16
[345323.067] (++) ARMSOC(0): Depth 16, (--) framebuffer bpp 16
[345323.067] (==) ARMSOC(0): RGB weight 565
[345323.067] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[345323.067] (==) ARMSOC(0): Default visual is TrueColor
[345323.067] (II) No BusID or DriverName specified - opening /dev/dri/card0
[345323.067] (II) Got BusID
[345323.067] (II) Opened DRM
[345323.067] (II)    DeviceName is [/dev/dri/card0]
[345323.067] (II)    bus_id is []
[345323.067] (II)    DriverName is [xilinx_drm]
[345323.067] (II)    version is [1.0.0]
[345323.067] (II) ARMSOC(0): Chipset: Mali
[345323.067] (**) ARMSOC(0): Option "Debug" "false"
[345323.067] (II) ARMSOC(0): Buffer Flipping is Enabled
[345323.067] (II) ARMSOC(0): umplock is Enabled
[345323.067] (II) ARMSOC(0): Setting the video modes ...
[345323.067] (II) ARMSOC(0): Adding all CRTCs
[345323.067] (II) ARMSOC(0): Got CRTC: 0 (id: 27)
[345323.101] (II) ARMSOC(0): Output DP-1 has no monitor section
[345323.134] (II) ARMSOC(0): EDID for output DP-1
[345323.134] (II) ARMSOC(0): Manufacturer: DEL  Model: a057  Serial#: 810441036
[345323.134] (II) ARMSOC(0): Year: 2011  Week: 20
[345323.134] (II) ARMSOC(0): EDID Version: 1.4
[345323.134] (II) ARMSOC(0): Digital Display Input
[345323.134] (II) ARMSOC(0): 10 bits per channel
[345323.134] (II) ARMSOC(0): Digital interface is DisplayPort
[345323.134] (II) ARMSOC(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[345323.134] (II) ARMSOC(0): Gamma: 2.20
[345323.134] (II) ARMSOC(0): DPMS capabilities: Off
[345323.134] (II) ARMSOC(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[345323.134] (II) ARMSOC(0): First detailed timing is preferred mode
[345323.134] (II) ARMSOC(0): Preferred mode is native pixel format and refresh rate
[345323.134] (II) ARMSOC(0): redX: 0.678 redY: 0.309   greenX: 0.202 greenY: 0.689
[345323.134] (II) ARMSOC(0): blueX: 0.148 blueY: 0.051   whiteX: 0.313 whiteY: 0.329
[345323.134] (II) ARMSOC(0): Supported established timings:
[345323.134] (II) ARMSOC(0): 720x400@70Hz
[345323.134] (II) ARMSOC(0): 640x480@60Hz
[345323.134] (II) ARMSOC(0): 640x480@75Hz
[345323.134] (II) ARMSOC(0): 800x600@60Hz
[345323.134] (II) ARMSOC(0): 800x600@75Hz
[345323.134] (II) ARMSOC(0): 1024x768@60Hz
[345323.134] (II) ARMSOC(0): 1024x768@75Hz
[345323.134] (II) ARMSOC(0): 1280x1024@75Hz
[345323.134] (II) ARMSOC(0): Manufacturer's mask: 0
[345323.134] (II) ARMSOC(0): Supported standard timings:
[345323.134] (II) ARMSOC(0): #0: hsize: 1280  vsize 800  refresh: 60  vid: 129
[345323.134] (II) ARMSOC(0): #1: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[345323.134] (II) ARMSOC(0): #2: hsize: 1920  vsize 1200  refresh: 60  vid: 209
[345323.134] (II) ARMSOC(0): #3: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[345323.135] (II) ARMSOC(0): #4: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[345323.135] (II) ARMSOC(0): #5: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[345323.135] (II) ARMSOC(0): Supported detailed timing:
[345323.135] (II) ARMSOC(0): clock: 241.5 MHz   Image Size:  597 x 336 mm
[345323.135] (II) ARMSOC(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[345323.135] (II) ARMSOC(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[345323.135] (II) ARMSOC(0): Serial No: F693T15A0NYL
[345323.135] (II) ARMSOC(0): Monitor name: DELL U2711
[345323.135] (II) ARMSOC(0): Ranges: V min: 49 V max: 86 Hz, H min: 29 H max: 113 kHz, PixClock max 305 MHz
[345323.135] (II) ARMSOC(0): clock: 148.5 MHz   Image Size:  597 x 336 mm
[345323.135] (II) ARMSOC(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[345323.135] (II) ARMSOC(0): v_active: 1080  v_sync: 1082  v_sync_end 1087 v_blanking: 1125 v_border: 0
[345323.135] (II) ARMSOC(0): clock: 74.2 MHz   Image Size:  597 x 336 mm
[345323.135] (II) ARMSOC(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[345323.135] (II) ARMSOC(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[345323.135] (II) ARMSOC(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[345323.135] (II) ARMSOC(0): clock: 27.0 MHz   Image Size:  597 x 336 mm
[345323.135] (II) ARMSOC(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[345323.135] (II) ARMSOC(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[345323.135] (II) ARMSOC(0): Number of EDID sections to follow: 1
[345323.135] (II) ARMSOC(0): EDID (in hex):
[345323.135] (II) ARMSOC(0):    00ffffffffffff0010ac57a04c594e30
[345323.135] (II) ARMSOC(0):    14150104b53c22783a8e05ad4f33b026
[345323.135] (II) ARMSOC(0):    0d5054a54b008100b300d100714fa940
[345323.135] (II) ARMSOC(0):    818001010101565e00a0a0a029503020
[345323.135] (II) ARMSOC(0):    350055502100001a000000ff00463639
[345323.135] (II) ARMSOC(0):    3354313541304e594c0a000000fc0044
[345323.135] (II) ARMSOC(0):    454c4c2055323731310a2020000000fd
[345323.135] (II) ARMSOC(0):    0031561d711e000a202020202020012e
[345323.135] (II) ARMSOC(0):    02031df1509005040302071601061112
[345323.135] (II) ARMSOC(0):    1513141f20230d7f07830f0000023a80
[345323.135] (II) ARMSOC(0):    1871382d40582c250055502100001e01
[345323.135] (II) ARMSOC(0):    1d8018711c1620582c25005550210000
[345323.135] (II) ARMSOC(0):    9e011d007251d01e206e285500555021
[345323.135] (II) ARMSOC(0):    00001e8c0ad08a20e02d10103e960055
[345323.135] (II) ARMSOC(0):    50210000180000000000000000000000
[345323.135] (II) ARMSOC(0):    0000000000000000000000000000004b
[345323.135] (II) ARMSOC(0): EDID vendor "DEL", prod id 41047
[345323.135] (II) ARMSOC(0): Using EDID range info for horizontal sync
[345323.135] (II) ARMSOC(0): Using EDID range info for vertical refresh
[345323.135] (II) ARMSOC(0): Printing DDC gathered Modelines:
[345323.135] (II) ARMSOC(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (8
[345323.135] (II) ARMSOC(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1082 1087 1125 +hsync +vsync (6
[345323.136] (II) ARMSOC(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsyn
[345323.136] (II) ARMSOC(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 k
[345323.136] (II) ARMSOC(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[345323.136] (II) ARMSOC(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e
[345323.136] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[345323.136] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[345323.136] (II) ARMSOC(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[345323.136] (II) ARMSOC(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (8
[345323.136] (II) ARMSOC(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 k
[345323.136] (II) ARMSOC(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 k
[345323.136] (II) ARMSOC(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e
[345323.136] (II) ARMSOC(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 k
[345323.136] (II) ARMSOC(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (6
[345323.136] (II) ARMSOC(0): Modeline "1920x1200"x0.0  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (7
[345323.136] (II) ARMSOC(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 k
[345323.136] (II) ARMSOC(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (7
[345323.136] (II) ARMSOC(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (6
[345323.136] (II) ARMSOC(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[345323.136] (II) ARMSOC(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vs
[345323.136] (II) ARMSOC(0): Modeline "1440x240"x0.0   27.00  1440 1478 1602 1716  240 244 247 262 -hsync -vsync (15.7 k
[345323.136] (II) ARMSOC(0): Modeline "1440x288"x0.0   27.00  1440 1464 1590 1728  288 290 293 312 -hsync -vsync (15.6 k
[345323.136] (II) ARMSOC(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 k
[345323.136] (II) ARMSOC(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vs
[345323.136] (II) ARMSOC(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsyn
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (2
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x0.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (2
[345323.136] (II) ARMSOC(0): Printing probed modes for output DP-1
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1082 1087 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (
[345323.136] (II) ARMSOC(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7
[345323.136] (II) ARMSOC(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5
[345323.136] (II) ARMSOC(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0
[345323.136] (II) ARMSOC(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5
[345323.136] (II) ARMSOC(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0
[345323.136] (II) ARMSOC(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0
[345323.137] (II) ARMSOC(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4
[345323.137] (II) ARMSOC(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz
[345323.137] (II) ARMSOC(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz
[345323.137] (II) ARMSOC(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e
[345323.137] (II) ARMSOC(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e
[345323.137] (II) ARMSOC(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e
[345323.137] (II) ARMSOC(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e
[345323.137] (II) ARMSOC(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e
[345323.137] (II) ARMSOC(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e
[345323.137] (II) ARMSOC(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e
[345323.137] (II) ARMSOC(0): Output DP-1 connected
[345323.137] (II) ARMSOC(0): Using exact sizes for initial modes
[345323.137] (II) ARMSOC(0): Output DP-1 using initial mode 1920x1080 +0+0
[345323.137] (II) ARMSOC(0): Got KMS resources
[345323.137] (**) ARMSOC(0): Display dimensions: (600, 340) mm
[345323.137] (**) ARMSOC(0): DPI set to (81, 80)
[345323.137] (II) Loading sub module "dri2"
[345323.137] (II) LoadModule: "dri2"
[345323.137] (II) Module "dri2" already built-in
[345323.137] (II) Loading sub module "exa"
[345323.137] (II) LoadModule: "exa"
[345323.137] (II) Loading /usr/lib/xorg/modules/libexa.so
[345323.137] (II) Module exa: vendor="X.Org Foundation"
[345323.137]    compiled for 1.18.0, module version = 2.6.0
[345323.137]    ABI class: X.Org Video Driver, version 20.0
[345323.137] (II) Loading sub module "fb"
[345323.137] (II) LoadModule: "fb"
[345323.137] (II) Loading /usr/lib/xorg/modules/libfb.so
[345323.138] (II) Module fb: vendor="X.Org Foundation"
[345323.138]    compiled for 1.18.0, module version = 1.0.0
[345323.138]    ABI class: X.Org ANSI C Emulation, version 0.4
[345323.140] (II) ARMSOC(0): Soft EXA mode
[345323.140] (II) EXA(0): Driver allocated offscreen pixmaps
[345323.140] (II) EXA(0): Driver registered support for the following operations:
[345323.140] (II)         Solid
[345323.140] (II)         Copy
[345323.140] (II)         Composite (RENDER acceleration)
[345323.140] (II) ARMSOC(0): Setting swap chain size: 2
[345323.140] (II) ARMSOC(0): [DRI2] Setup complete
[345323.140] (II) ARMSOC(0): [DRI2]   DRI driver: armsoc
[345323.140] (==) ARMSOC(0): Backing store enabled
[345323.140] (==) ARMSOC(0): Silken mouse enabled
[345323.140] (II) ARMSOC(0): HW cursor init()
[345323.140] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[345323.141] (==) ARMSOC(0): DPMS enabled
[345323.141] (--) RandR disabled
[345323.141] (EE) AIGLX error: dlopen of /usr/lib/dri/armsoc_dri.so failed (/usr/lib/dri/armsoc_dri.so: cannot open shar
[345323.141] (EE) AIGLX: reverting to software rendering
[345323.150] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[345323.151] (II) AIGLX: Loaded and initialized swrast
[345323.151] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[345323.151] (II) ARMSOC(0): Setting screen physical size to 508 x 285
Scholar watari
Hi @karen
Would you try to change value of "DefaultDepth" from 16 to 24 ?
[Reason]
"Dell monitor" only support the following color encoding.
However, it described as "DefaultDepth = 16" on xorg.conf.
Therefore, I'm sure, DisplayPort malfunctions to output video data as RGB=565 (16bit), which is not supported, to "Dell monitor". Then "Dell monitor" displays black screen.
[Note]
BTW, the resolution of this "Dell monitor (U2711)" is "2560x1440". It's little special.
I suggest to change another DP monitor, if you have another monitor with DP.
Thank you.
Best regards,
Visitor karen
Thanks very much for your help. The problem is finally settled.
however, I have a one more question.
I'm trying to run the tricube application use another BOOT.bin and image.ub file
then, the following error message appears(red color).
Thank you in advance...........
root@xilinx-zcu102-zu9-es2-rev1_0-2017:~# export DISPLAY=:0.0
root@xilinx-zcu102-zu9-es2-rev1_0-2017:~# /usr/bin/Xorg -depth 16&
[1] 2223
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 2.6.32-573.el6.x86_64 x86_64
Current Operating System: Linux xilinx-zcu102-zu9-es2-rev1_0-2017.2 4.9.0 #1 SMP Sun Oct 8 00:35:48 KST 2017 aarch64
Kernel command line: earlycon clk_ignore_unused
Build Date: 19 June 2017  09:37:47PM
Current version of pixman: 0.34.0
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 13 10:22:41 2017
root@xilinx-zcu102-zu9-es2-rev1_0-2017:~# /tmp/tricube
/tmp/tricube: error while loading shared libraries: libMali.so.1: cannot open shared object file: No such file or directory
Scholar watari
Hi @karen
I guess that the following URL is helpful for you.
Please refer the following URL.
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8BMPSoC+Graphics-+GPU+application+debugging+using+ARM+Mali+Graphics+Debugger+tool
But, it has mistake in this content.
"ln -s /usr/lib/libMali.so.7 /usr/lib/libMaliso.1" shall be replaced with "ln -s /usr/lib/libMali.so.7 /usr/lib/libMali.so.1".
Thank you.
Best regards,
