Visitor aubogdan
Displayport RX problem with MSA registers
Hi!
I am working with the DisplayPort IP block and configuring it as  sink core (the DisplayPort v7.0) with  2 lanes. 2 lanes are trained.
I successfully transfer images from my TX part to the sink core without scrambling. The main stream attributes packet is OK. Reading the MSA registers (0×500 - 0×538), I see the values that I set for the TX transmitter.
But when I enable scrambling on the both sides I get strange result:
— Image is being transmitted correctly ();
— the value for MSA registers  received on 0 lane are correct, but the MSA registers received on 1 lane are not correct (I get MSA_NVID = 009C7133, but expect MSA_NVID = 00800000).
I transfer next image: 640×480×75Hz.
Why the attributes packet transmitted on 1 line is not correctly recognized by DP Sink core when scrambler is enabled ?
What I did wrong ?
Scholar watari
Re: Displayport RX problem with MSA registers
Hi @aubogdan
Is your mentioned about simulation ?
If yes, you turn on inter skew function on DP Tx.
Because it's link training issue during inter skew adjustment.
If no, I suggest you to consider your schematic.
And, I mentioned again.
This IP is obsoluted. I strongly suggest you to use latest DP Rx IP.
Scholar watari
Hi @aubogdan
First of all, I strongly suggest you to latest Xilinx DP Rx IP.
Because you mentioend DP Rx IP is obsoleted.
BTW, what do you mean "scrambling" ?
Do you use HDCP ?
If yes, you need to implement HDCP core.
If no, it seems SSC issue.
How much percentage do you use for SSC ? Is it under specification of DP ?
Visitor aubogdan
Hi, @watari
I do not use HDCP.
Under scrambling, I mean next:
DPCD_SCRAMBLING_DISABLE. Value of the scrambling disable field of the DPCD
training pattern register. By default, scrambling is disabled.
• [0] – Set to 1 when the transmitter has disabled the scrambler and transmits all
symbols.
What is a SSC ?
Thank you I will try to use the latest version of Xilinx DP Rx IP.
Scholar watari
Hi @aubogdan
How do you connect DP signal between source and sink ?
Do you use DP retimer between them ?
Also what link rate do you use ?
It seems link training issue.
BTW, as I already mentioned before, I strongly suggest you to use latest DP Rx IP.
What you use DP Rx IP is obsoluted.
Visitor aubogdan
1. "How do you connect DP signal between source and sink ?"
displayport_rx_2x u_displayport_rx_2x (
.lnk_rx_lane_p ({gt1_gtxtxp,gt0_gtxtxp} ),
.lnk_rx_lane_n ({gt1_gtxtxn,gt0_gtxtxn} ),
2. "Do you use DP retimer between them ? "
What do you mean ?
3." Also what link rate do you use ?" I use 1.62 Gb/s.
I think it is not link training issue. Because 2 lanes are trained and I successfully transfer my dates.
Scholar watari
Hi @aubogdan
Visitor aubogdan
Hi @watari
I am speaking about the simulation.
At first, I will try to use the latest version of DP RX IP from Xilinx.
Thank you!
Hi @aubogdan
As mentioned by @watari you should move to the displayport subsystem IP.
However note that simulation is not supported for the displayport subsystem IP.
You will only get support from Xilinx if you can reproduce this issue on HW.
