Displayport Rx AUX channel termination
  My custom board has Displayport Rx, the AUX channel is connected to 2.5V HR bank. As per VESA DP standard, AUX needs AC coupling and DC bias. The board uses 100nf for AC coupling, and 50 ohm resisters  pullup to 1.25V at FPGA side.
When I probe the aux chanels, the waveform is strange, data packet's voltage amplitude is not the same. Does this  related to incorrect terminations?
Re: Displayport Rx AUX channel termination
Hi @xxhc417s,
Yes it might be a wrong termintation. You might want to check the Inrevium DP FMC card for a compliant solution
Florent
Thankyou for your reply. I didn't have dp fmc card, instead the schematic about aux termination is the same as ug417 fig. 1-72 without on board Rdiff=100Ω(use on chip 100Ω)。GPU can read edid through aux channel。Can you describe how the dp rx fmc card be terminated?
Hi @xxhc417s,
The termination on the FMC card is as documented in the FMC card:
1MOhm pull pup -> capacitor -> 50 ohm register followed by a level shifter.
How are you doing the bidirectional? Is is internal to the FPGA or do you have an external buffer. Note that Xilinx mainly tested with external buffer (with unidirectional LVDS)
Florent
I use internel bidirectional instead of external levelshifter. The aux channel connection between connector and DP rx
: 1MOhm pull pup -> capacitor -> 50 ohm resister pullup to 1.25V then to FPGA HR bank.
Though the aux channel waveform is not good, GPU can read corrected EDID.
Hi @xxhc417s,
Could it be that your waveform analyzer is creating this floating waveform?
If GPU can access EDID, it might not be an issue.
Florent
HI @xxhc417s,
Do you have any updates on this?
Florent
    There is no update about this topic. DP Rx still cann't work for which you can reference this. Now I'm checking the power supply that feeds to GTX.
HI @xxhc417s,
Were you able to have your link working?
Florent
  No, the board still can not work. I will keep updating.
Best Regards,
Scholar watari
Hi @xxhc417s
Would you share version of DP Rx and a schema around DP ?
Also, would you turn off SSC at GPU, if possible ?
BTW, can you receive VGA video timing via DisplayPort ?
It means that I'd like to confirm whether it works fine under RBR (1.27Gbps) or not.
Best regards,
Where is it possible to get the schematic for the FMC card?
Thank you!
Hi @marcis_greitans ,
You can get the schematic if you have bought the FMC card. Please contact your FAE
Florent
