Visitor tommymc
Displayport Subsystem IP not supported on Artix-7? Why not?
I am designing a product which requires Displayport Tx and currently developing on Digilent's Nexys Video board, but none of the Xilinx Displayport Subsystem IP seems to be supported on Artix-7.
The Nexys Video board (with XC7A200T-1SBG484C) has the required GTP which should meet DP spec. even for DP1.3, and it is in fact routed to a mini-Displayport connector on the board.
Is there any possible way to implement this IP in my design?
Re: Displayport Subsystem IP not supported on Artix-7? Why not?
Hi @tommymc,
The DisplayPort SubSystem does not support Artix-7 devices. Due to clocking, fabric, and density, I do not recommend using Artix devices for DP/HDMI cores.
If you choose to move forward with an Artix device, you may be able to add a DP Tx interface to your design. The DisplayPort 7.0 core (not SubSystem) was available Vivado 2017.2 and earlier. I believe that this core can target Artix devices. I do not recommend using discontinued IP
Without knowing your project requirements, my suggestion is to move to a Kintex device and use the DisplayPort SubSystem and the latest release of the Vivado tools.
Sam
Xilinx Video Design Hub
Hi @tommymc,
Sam
