Does VCU support XAVC?
 while XAVC uses level 5.2 of H.264/MPEG-4 AVC,  it seems VCU can support XAVC.
I use ZCU104 card and run omx_decoder command, it cannot decode the XAVC-coded streams.
so, does it support XAVC, and how?
Tags (2)
Re: Does VCU support XAVC?
XAVC is 4:2:2 10bit, Does VCU support 4:2:2 10bit decode?
Hi @gefei-liuqi,
The VCU supports 10 bit. As per the following topic, the VCU TRD 2018.3 should support it:
https://forums.xilinx.com/t5/Video/SDI-Video-to-10-Bit-H265-MPEG/m-p/912290
Florent
