ECC Block RAM within System Generator
Is there a way to enable error correcting code (ECC) on the block rams used within System Generator.   For example, for the FIR coefficients, sine/cosine lookup table for NCO, and FFT phase factors.
Sorry, I already had posted this in 'Design Tool - Others', before I saw the DSP forum.
Re: ECC Block RAM within System Generator
Currently there is no way to enable ECC for the Block Ram in System Generator for DSP.
You would need to generate the block ram using the Memory Generator IP and then pull in the memory as a black box.
Chris
Video Design Hub | Embedded SW Support
Are  there any plans to implement native System Generator ECC-support in future versions?
