Observer sabiya
EDID Ip Block
I need a EDID ip block on vivado 2019.1 for my project.
please help me it will not available in vivado.
Re: EDID Ip Block
Hello @sabiya
Please provide use some more details to understand your query clearly:
1. Your requirement and application details
2. Are you referring to any Xilinx example design? Please provide details.
Bhushan
Observer sabiya
Re: EDID Ip Block
I implemented video display port receiver subsystem example. In that they given Vid_EDID block and Video frame CRC block. I need that two blocks seperate files.
Re: EDID Ip Block
Hi @sabiya
The Vid_EDID block and Video frame CRC block are what we call helper cores. They are used in the example design to demonstrate the behaviour of the Displayport core but they are not supported by Xilinx. Users are expected to write their own IPs for this blocs. This is why they are not part of the IP catalog and why there is not documnetation available.
You could potentially start from the example design to do your own project, but keep in mind that this is not fully supported.
Florent
