Participant yashaswini.shankar
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_vproc_ss::generate : ERROR: [Common 17-161] Invalid option value '' specified for 'object'. Hai All,
-In the design we are using video processing subsystem IP for scaling but during generation of device tree in sdk we are facing below error
-Same is repeated when we tried to build project in petalinux 18.3 for our custom board
-SDK used 18.3
ERROR: device-tree-xilinx+gitAUTOINC+b7466bbeee-r0 do_configure: Function failed: do_configure (log file is located at /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_configure.4561)
ERROR: Logfile of failure stored in: /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_configure.4561 Log data follows: |
DEBUG: Executing shell function do_configure | MISC_ARG is -hdf_type hdf -yamlconf /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/device-tree.yaml | APP_ARG is -app "device-tree" |
Using xsct from: /home/yashaswini/petalinux_18.3/tools/xsct/SDK/2018.3/bin/xsct | cmd is: xsct -sdx -nodisp /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl -ws /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/../components/plnx_workspace/device-tree -pname device-tree -rp /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/git -processor psu_cortexa53_0 -hdf /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/deploy/images/plnx-zynqmp/Xilinx-plnx-zynqmp.hdf -arch 64 -app "device-tree" -hdf_type hdf -yamlconf /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/device-tree.yaml |
INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds | hsi::open_hw_design: Time (s): cpu = 00:00:06 ; elapsed = 00:00:07 . Memory (MB): peak = 783.754 ; gain = 174.000 ; free physical = 28463 ; free virtual = 30829 |
WARNING: Interrupt pin "irq" of IP block: "SDI_OUT_SDI_OUT1_v_tc_0" is not connected to any interrupt controller | | WARNING: not supported pl_clk: | WARNING: no s_axi_aclk for clockwizard | WARNING: not supported pl_clk: |
WARNING: quotes to be removed or use 2018.1 version for &sata params param0..param7 | WARNING: quotes to be removed or use 2018.1 version for &sata params param0..param7 |
WARNING: Frequency 33.333333 used instead of 33.333 |
WARNING: Only boolean type can have empty value. Fail to add driver(ddr4_v_frmbuf_wr_0) property(reg) type(intlist) value() | WARNING: Please add the property manually |
WARNING: Only boolean type can have empty value. Fail to add driver(ddr4_v_proc_ss_0) property(reg) type(intlist) value() |
ERROR: [Common 17-161] Invalid option value '' specified for 'object'. |
ERROR: [Common 17-161] Invalid option value '' specified for 'object'. | | while executing | "get_property IP_NAME $in_ip" | (procedure "::sw_vproc_ss::generate" line 61) |
invoked from within | "::sw_vproc_ss::generate ddr4_v_proc_ss_0" |
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate() | hsi::generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:07 . Memory (MB): peak = 798.754 ; gain = 15.000 ; free physical = 28419 ; free virtual = 30786 | generate_target failed | while executing | "error "generate_target failed"" | invoked from within |
"if {[catch {hsi generate_target -dir $project} res]} { | error "generate_target failed" | }" |
(file "/home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/dtgen.tcl" line 38) | WARNING: exit code 1 from a shell command. |
ERROR: Function failed: do_configure (log file is located at /home/yashaswini/Project/ASCE4/iWave_proj_4eg_18.3/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_configure.4561)
ERROR: Task (/home/yashaswini/petalinux_18.3/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 7417 tasks of which 7416 didn't need to be rerun and 1 failed. Summary: 1 task failed: /home/yashaswini/petalinux_18.3/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure Summary: There was 1 ERROR message shown, returning a non-zero exit code. ERROR: Failed to build project
Can anyone help me to resolve this issue ?
Yashaswini
Re: ERROR: [Hsi 55-1545] Problem running tcl command ::sw_vproc_ss::generate : ERROR: [Common 17-161] Invalid option value '' specified for 'object'. Hai All,
Hi @yashaswini.shankar
Could you share your HDF file this way I can reporduce the issue on my end and analyse?
Florent
Hai @florentw ,
Thank you for your reply.I have attached hdf file along with this reply.Please go through and let me know about the changes.
Thank you
Yashaswini
HI @yashaswini.shankar
The issue is happening because the Device tree generator is not expecting to have the AXI4-Stream Subset converter connected to an external AXI4-Stream interface.
I have create the simple patch attched for petalinux. To install the patch
  • Copy the patch to project-spec/meta-user/recipes-bsp/device-tree/files
  • update the device-tree.bbappend as follows
    FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
    SRC_URI += "file://system-user.dtsi"
    SRC_URI_append += " file://0001-Fix-external-AXI4S-interface-to-AXI4S-converter-for.patch"
Florent
