Participant prasanna_18
Enable HS and ESC Timeout counters/registers in MIPI CSI-2 Receiver Subsystem v3.0
 In our design we are using MIPI CSI-2 Receiver Subsystem v3.0  logiCore IP.
In that IP has MIPI D-PHY block.When I try customizing that block (we want to enable Enable HS and ESC Timeout counters/registers ) it doesn't reflect  in the block.
Not able to enable that interface.how can we enable that feature in our design?.
Re: Enable HS and ESC Timeout counters/registers in MIPI CSI-2 Receiver Subsystem v3.0
Hello @prasanna_18
As already mentioned by @bpatil, since you are using older version of MIPI CSI-2 Receiver Subsystem,
MIPI DPHY IP is set as a read-only IP and parameter modification cannot be easily done.
-- Manual RTL modification can be done, but I do not recommend this method.
Instead, we already added a new IP features in Vivado 2018.3.
Could you please download the latest Vivado and try the following step ?
0. Open MIPI CSI-2 Receiver Subsystem wizard GUI.
1. Check "D-PHY Register interface"
2. Check "Enable HS and ESC Timeout Counters/Registers"
3. Set the suitable HS and ESC Timeout value that fit your system
Hope this helps.
Leo
Hello @prasanna_18
You are not able to change any option of MIPI DPHY IP inside MIPI CSI-2 IP as it is read only.
Bhushan
Hello @prasanna_18
Hope this helps.
Leo
HI @prasanna_18,
Do you have any updates on this? Were the replies from @karnanl and @bpatil enough for you?
Thanks and Regards,
Thanks for your patience and  support for this issue.
We will get back to you when we need your help.
