Enabling PL-DDR
I am using ZCU104 board and working on a project about VCU IP with ZCU104 BSP. I want to enable the PL-DDR; in PG252 page 113 there is a section about it. But I dont think it is well described. I think I need to add some new IPs but I dont know which ones to add. I also dont know how to connect them.
Does anybody have an idea and help me about it, please?
Re: Enabling PL-DDR
Hi @yildizbilgin
Yes PG252 page 113, is what you need
Re: Enabling PL-DDR
Hi @yildizbilgin
You need to add the Zynq UltraScale+ EV Architecture Video Codec Unit DDR4 LogiCORE IP as described in pg252 chapter 6 ...
Re: Enabling PL-DDR
Zynq UltraScale+ EV Architecture Video Codec Unit DDR4 LogiCORE IP is already in the project. Chapter 6 doesnt explain the PL-DDR, it explain PS-DDR which is already in the project and already connected.
Re: Enabling PL-DDR
Hi @yildizbilgin
The Zynq UltraScale+ EV Architecture Video Codec Unit DDR4 LogiCORE IP is to connect the PL DDR. This is explained in the PG., please read it carefully
Re: Enabling PL-DDR
Hi @florentw ,
But The Zynq UltraScale+ EV Architecture Video Codec Unit DDR4 LogiCORE IP is already in the BSP project, what things should i change I still dont know.
In PG252 page 113, i followed the steps. Is it enough?
Re: Enabling PL-DDR
Hi @yildizbilgin
