Participant tuanho27
Error when open IP example design HDMI TX/RX
Hello guys,
I am working on HDMI examples, my target board: KC705, OS: Ubuntu 16.04, vivado rev 17.04.
Since I can not program the HDCP keys (license) as the xapp1287 instruction. I've created an example follow the document: HDMI 1.4/2.0 Receiver Subsystem v2.0 (Chapter 5), yet I got an unexpected error (as attached pics) and I don't know the reason even read some researches.
The error appear when I open IP example and new vivado project created.
Can anyone give me a suggestion?
Thanks and Best Regards,
TuanH
Re: Error when open IP example design HDMI TX/RX
Hi @florentw
      >>1. Could you try another path for the TPG license? (ex /home/tuanho/licenses/ )
      >>2. open the license for the TPG with a text editor and make sure there is tpg written
Yes, I've tried as you said many times even try to generate the license again from Xilinx/license manager. It doesn't work. :(
However, in the *.lic file of TPG license, I see this info (it's different with other .lic file) :
SERVER tuanho 107B4446D1EB 2100
USE_SERVER
and
# The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE TPG xilinxd 2019.05 BB363751B164 COMPONENTS="v_tc v_tpg" \
OPTIONS=SUITE
I wonder that do I need to re-setup the proxy??
Tuan
Hi @tuanho27,
Could you share the vivado.log file which contains the error? (type pwd in the tcl console to know where it is created).
Florent
Hi @florentw
Thank you for reply.
I attached log file. It seems that I lack the license for Video Test Pattern Generator, but I've added this license from www.xilinx.com/getlicense
May I missed something?
Best,
Hi @tuanho27,
1. Could you try to point to this license directly in the XILINXD filed of Vivado Liense manager?
2. Then still in VLM, make sure you can see the TPG license and the host ID match is yes for this license
3. If this doesn't help, please provide the txt file generated with the tcl command report_environment -file report.txt
Florent
First, I wanted to point out that XAPP1287 has been replaced by the example designs provided with HDMI Rx/Tx Subsystems and should no longer be used as a starting point for HDMI Rx/Tx Subsystem Designs.
You can find the example designs here:
 - PG235 Chapter 5 - HDMI Tx Subsystem
 - PG236 Chapter 5 - HDMI Rx Subsystem
Second, as was pointed out you also need a license for the Test Pattern Generator.  This is a free license that you can fine at https://www.xilinx.com/getlicense
Third, you must have an HDCP IP license in order to generate the example designs with HDCP capabilities.  You will need to be an DCP adopter and will need to contact your local FAE or Sales office in order to purchase a license.  See the following Forums post that has already addressed this issue.
Chris
Video Design Hub | Embedded SW Support
Mentor watari
Mentor
Hi @tuanho27
First of all, I just ask you.
Are you or your company licensee of HDCP ?
If no, you can not implement HDMI with HDCP.
If yes, you need HDCP key license to implement HDMI with HDCP and I suggest to ask your local Xilinx's agent or Xilinx for it.
It's a rule from Digital Content Protection, LLC to protect copyright.
So, say again. If you are not HDCP licensee, I suggest to implement HDMI Tx/Rx design without HDCP.
Best regards,
Hello @florentw,
I put all license file (vivado tools, LogicCORE and TPG) in /home/tuanho/.Xilinx/* and then load vlm, but after load license it just exist license for tools, no license for IP. (I added my env. report)
It seems that vlm cannot load the license of LogicCORE and TPG. Is there any other step that I need to do?
@chrisar@watari Thank you for your answer, since I do not have license of HDCP so I make example of HDMI Tx/Rx design without HDCP (in document guide above), but I stuck when try to generate a IP design example.
Best,
Hi @tuanho27,
1. Could you try another path for the TPG license? (ex /home/tuanho/licenses/)
3. Make sure you are indicating the path in XILINXD_LICENSE_FILE field as mentioned earlier
Florent
Hi @florentw
USE_SERVER
and
OPTIONS=SUITE
Tuan
Hi @tuanho27,
It seems that you have generate the license as a floating license. Is it what you wanted? Is it on a server?
I think you need to regenerate the license to be a node locked  license and it should work.
Florent
Hi @florentw
Thank you very much for your reply.
  >>It seems that you have generate the license as a floating license. Is it what you wanted? Is it on a server?
Oh, maybe I misunderstood for this.
Now, I just tried to delete and re-generate the license (a node locked as you said) but it doesn't have a permission  (error notice as image)
What I suppose to do when it say I need submit a Service Request ?
Best Regards,
Hi @tuanho27,
You need to go to the Service Portal and click on Licensing to create a Service Request for licensing issues.
Customer Services will take care of this and re-enable the license for you.
Florent
Hi @florentw
Thank you for your kindly support.
I submitted request to Service team and got feedback from them. Now I can use the TPG license well.
Best Regards,
Tuan H
