Ethernet and VDMA
Maybe someone can help me.
I want transmit video to ethernet and recieving signal of control. But i have some problem. After i have initialized vdma in my project, the receiving part of the ethernet stops working.
int main()
	struct ip_addr ipaddr, netmask, gw;
	/* the mac address of the board. this should be unique per board */
	unsigned char mac_ethernet_address[] =
	{ 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
	echo_netif = &server_netif;
	init_platform();
	/* initliaze IP addresses to be used */
	IP4_ADDR(&ipaddr,  192, 168,   1, 10);
	IP4_ADDR(&netmask, 255, 255, 255,  0);
	IP4_ADDR(&gw,      192, 168,   1,  1);
	print_app_header();
	print_ip_settings(&ipaddr, &netmask, &gw);
	lwip_init();
  	/* Add network interface to the netif_list, and set it as default */
	if (!xemac_add(echo_netif, &ipaddr, &netmask,
						&gw, mac_ethernet_address,
						PLATFORM_EMAC_BASEADDR)) {
		xil_printf("Error adding N/W interface\n\r");
		return -1;
	netif_set_default(echo_netif);
	/* now enable interrupts */
	platform_enable_interrupts();
	/* specify that the network if is up */
	netif_set_up(echo_netif);
start_application();
	int Status;
	Status =  GPIOControl_Init();
	if (Status != XST_SUCCESS) {
		 xil_printf("Initializaton GPIO failed with error = %d\r\n",Status);
		 return XST_FAILURE;
		} else {
		 xil_printf("Initializaton GPIO is OK \r\n");
	GPIO_Write(0x01);
	GPIO_Write(0x00);
	init_vdma();	// if i delete this code ethernet will work normal
/* receive and process packets */
	while (1) {
		xemacif_input(echo_netif);
		transfer_data();
	/* never reached */
	cleanup_platform();
	return 0;
If i delete initialization vdma receiving part of ethernet work normal
int init_vdma()
	int RegVal, status;
	    RegVal    = 0x04;
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0x30, RegVal);
	    RegVal    = 0;
	    while(RegVal & (1 << 2))
	        RegVal    = Xil_In32(XPAR_AXI_VDMA_0_BASEADDR + 0x30);
	    RegVal            = Xil_In32(XPAR_AXI_VDMA_0_BASEADDR + 0x34);
	    RegVal            = RegVal | 0x1000;// 0xFFFFFFFF;
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0x34, RegVal);
	    RegVal    = RegVal | 0x108B;
		IntrCntrConfig	= XScuGic_LookupConfig(XPAR_PS7_SCUGIC_0_DEVICE_ID);
		if (IntrCntrConfig == NULL)	return XST_FAILURE;
		status			= XScuGic_CfgInitialize(&Intc, IntrCntrConfig, IntrCntrConfig->CpuBaseAddress);
		if (status != XST_SUCCESS)	return XST_FAILURE;
	    status = XScuGic_Connect(&Intc, XPAR_FABRIC_AXI_VDMA_0_S2MM_INTROUT_INTR, (Xil_InterruptHandler)DMA_TransferEnd_Handler, NULL);
	        return XST_FAILURE;
	    XScuGic_SetPriorityTriggerType(&Intc, XPAR_FABRIC_AXI_VDMA_0_S2MM_INTROUT_INTR, 0, 3);
	    XScuGic_Enable(&Intc, XPAR_FABRIC_AXI_VDMA_0_S2MM_INTROUT_INTR);
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xAC, ptrBufFrame);
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xAC+4, ptrBufFrame + 0x4B0000);//307200(1BB8000) =640*480*(40)
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xAC+8, ptrBufFrame + 0x960000);//307200 (3770000)=640*480*2*(40)
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xA8, 0x500);//640*2
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xA4, 0x500);
	    Xil_Out32(XPAR_AXI_VDMA_0_BASEADDR + 0xA0, 480);
	    return 0;
Re: Ethernet and VDMA
Hi @bwiec!
I know reason my problem, but i don't know how do it. I think I've break the ethernet interrupts after i tune in vdma interrups.
How i can tune in interrupts vdma and ethernet together in my project ??
Help, please!
hello,
you should check your interrupt configuration.
Could be many things. Can you detail exactly what happens when the 'ethernet stops working?'
One thing to be careful about is to make sure the VDMA's data buffers aren't over-lapping and corrupting some code region of memory (check your linker script).
How are you allocating ptrBufFrame ? Make sure your appropriate linker script section has enough memory to store multiple full frames of video data plus whatever else is going on in the code.
www.xilinx.com
Hi @bwiec, thank's for your answer.
'ethernet stops working' it's mean that board doesn't recive packets if i initialization vdma.
Can you explain or  give me link what is 'check your linker script' and how i can do it (i am beginner in programming).
I don't understand about  "How are you allocating ptrBufFrame ?"  sorry i am beginner.
Hi @theultimatesource, thank's for your answer! i am trying verify this
That's okay, no problem. In SDK, right-click on the C project and select 'Generate Linker Script.' Post a screenshot of it.
Can you post a snippet of code showing how you declared ptrBufFrame variable? i.e. Did you use malloc, or just declare a huge array statically? Or is it just a pointer with no allocation at all? Is it global or local?
www.xilinx.com
ptrBufFrame is just a pointer. It's global
u32 ptrBufFrame = 0x01000000;
I noticed that receiving doesn't independ from vdma. if i add to echo example my code ( i create new udp_pcb, then do blind and connect), i see what receiving stop working
Hi @bwiec!
Help, please!
@ant_lipl_7030,
told ya 😉. what happens is that you configure your interrupts for lwip, then reconfigure them AGAIN for VDMA ergo lwip stops working. you'll need to do that separately.
Hello, @theultimatesource !!
Yes, you told, but I understand that I do not initialize the VDMA interrupt at all. My code is wrong. I don't know how to set the interrupt correctly. maybe can u me help in this issue?
