Visitor wfzhangtong
FPGA Accelerating RTSP and H.264 video decode
I want to decode RTSP and H.264 video with FPGA accelerating.
My development board is z-turn 7010 that base on ZYNQ-7000 SoC XC7Z010.
I think there are 2 ways:
  1. use a H.264 decode FPGA IP
  2. use SDSoC accelerating my software code (ex. ffmpeg) by add relevant funtions to hardware functions list
Which way is reliable and simple?
Which IP for way 1?
Is there better way?
Tags (4)
Re: FPGA Accelerating RTSP and H.264 video decode
Hi @wfzhangtong,
Both way should be reliable (it depends on your algorithm for SDSoC though). But I would recommend using an IP as you know it is working in HW.
For the simple side, it depends on which field you are more comfortable, SW or HW?
Which IP for way 1?
We have few partners for H.264 decoder soft IPs as coreEL, PathPartner, IBEX and SOC Technologies. See the Audio & Video Codec page information on our partners for codec IPs.
Did you thought about using a Zynq MPSoC EV with a harden VCU? It might be more expensive than using a Zynq-7000 but might be a solution to consider. You might want to discuss this with one of our authorized distributor.
Hope that helps,
Florent
Tags (2)
Hi @wfzhangtong,
Which IP for way 1?
Hope that helps,
Florent
Tags (2)
