Observer prateek33
Get raw data from VDMA in Petalinux
I have been working on Zynq Base TRD 2015.4, where I was trying to change the filter to something else. I recently came across this site. It lists a method to install Ubuntu 2016.4 on the ZC702. Which gave me the idea of implementing the said filter in Ubuntu. To do this, I was thinking of using the OpenCV Python library and the raw data from the VDMA stored in memory but I can't seem to find a way to access it. Could anybody help me with how I can access raw VDMA data in Ubuntu so that I can process it and display via HDMI?
Tags (2)
Re: Get raw data from VDMA in Petalinux
You can find more information on the Xilinx DMA (and VDMA) Linux Drivers on the Xilinx Wiki for the DMA Drivers.
Chris
Video Design Hub | Embedded SW Support
HI @prateek33,
Do you have any updates on this? Did the reply from @chrisar helped?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
