Observer cbranson
Getting Signals not listed in AccelDSP, can it be done?
I am currently using FIFOs and I'd like to have use of the RD_ACK signal that is available under the system generator.  How can I edit the block so I have use of this signal?  I'd assume it can be done somehow since the signal is listed in the core generator that is used.
Currently I'm using an inverted empty signal with delay, however the timing diagram shows it changing on a falling edge which makes me uneasy especially since my counters are reporting more data than expected.  I'd also like to know how to do this because it could be applied to other blocks where I've wanted to do the same thing.
