Visitor roiberts
H.264
Dear Forum
As a begin of my research, I have to implement a H.264 Encoder for HD Video, 10fps, in a  zynq 7000 family.
Question is:
*what device of this family could be better to use ?
*maybe already exist a table showing performace vs device ?
Any useful info is apreciate.
Thanks very much
Roberto
回复: H.264
Are you going to develop your own h.264 coder?Or IP? 1: I suggest you use zynq7100 because it has more resources. 2. You can use a hardcoded soc chip (Hi3510) to display output on zynq.
Visitor roiberts
回复: H.264
Thanks for reply
In Zynq I want develop a H.264 codec + other elaboration .
I woluld like to know how many resources are used ,depending on performance or other parameter...Im not the first to do this work, so,I hope to have a aproximate measure about resource.
Roberto
回复: H.264
Ok, we are using the 690t of V7 series, referring to our previous h.264 codec project, the ram resources on the chip are relatively tight, so you should pay attention to this, and you should know how many channels of output are needed, and we used 4 channels of output on our project.
Visitor roiberts
回复: H.264
Thanks again for reply
If I can I ask another question:
-As a long study path,what is the best way to start; example ,realize first in C/C++ or ??
-Are the resource dependent of FPS ? That means, a 10fps compared to a 30fps ,what caracteristic change in my FPGA selection?
-Some reference if possible ?
Thanks for help
Roberto
回复: H.264
HI @roiberts
Florent
