Visitor apatro
H265 -> output data stream
Trying to find information on what Xylinx can do with video. Looking to do the following:
4k sensor-> co-processor OR encoder OR SOM or something that does H265 -> output data stream // stream input -> H265 decoder -> video output.
All of this at under 100ms or lower and with very little power draw.
Re: H265 -> output data stream
Hi @apatro ,
You might want to look at the ZynqMPSoC EV devices which have an integrated H.264/H.265 Video Codec Unit and which can do simulatneous 4K encode and decode.
For the camera interface you could use a MIPI interface.
A good example design is the VCU TRD on the ZCU106 board.
You might want to look at pg252 for information on the video codec unit and the latency.
Florent
Hi @apatro ,
Florent
Hi @apatro ,
Do you have any updates on this? Was my reply enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
