Observer hariprasadb
HDMI Audio loopback with DDR write and read
I am using HDMI RX and TX subsystem for Audio & video processing application using ZCU102 kit. I have some doubt with Audio interface to HDMI TX subsystem.
Initially I generted HDMI RX-TX loopbck example design and I observed the audio behaviour when HDMI RX is connected and not connected.
Then I have exported Audio out from HDMI RX and Audio In to HDMI TX subsystem and looped back in the top module & found the audio behaviour is fine.
Now I have written the Audio samples to PL DDR4 and reading from the same location. I am seeing the written and read audio samples are matching. I added ILA for Audio Write to DDR and read from DDR , the capture is exported to .csv files and compared the samples and written and read samples are matching. Currently I have retained the preamble and MSB 4 bits as  it is. DDR write and read happens burst of 128 words/samples at a time to DDR4.
Then by seeing the Audio_tready from HDMI TX subsystem IP, I was simply sending the 32-bit samples with proper handling of tid(channel ID ) bus. Here I expected proper audio whichever I was playing in the source. But, hearing some noise although I send the proper samples.
To check the Audio sample handling, I was referring to Xilinx's Audio generator source code and found that each fream (subframe  0 & subframe 1) are sent for every 512 cycles but, not continuous. I followed the same but don't know the reason for the same.
Still the issue is not solved and same noise is played in HDMI monitor.
Let me know any special consideration/synchronization to specific events to be made to handle the audio samples.
With Regards,
Hariprasad Bhat
Re: HDMI Audio loopback with DDR write and read
@hariprasadb
Do you have audio analyzer to analyze the audio? You have checked the audio samples, can you check if you have changed the sample rate of audio? Without PL DDR4, do you see this issue? Do you test L-PCM audio or HBR? Which version of Vivado are you using?
I attached the ILA capture showing frame-1, frame-2 and continuous frame transfer to HDMI subsystem IP
With regards,
Hariprasad Bhat
@hariprasadb
Thank you for your suggestions.
I analyzed further and found that my logic was not pumping the valid data to HDMI TX subsystem. I corrected my DDR read logic and now able to hear the proper audio.
With Regards,
Hariprasad Bhat
However, I am hearing some noisy amplitude coupled through out the  audio which I is played if I do DDR write and read. If I simply loopback this issue is not observed. The distinct noisy behaviour is identified if the loudness of the audio being played is more.
Does anybody encountered this issue? like generally if any sample missesd while writing to DDR and read from DDR could result this kind of behaviour?  Currently I am debugging my RTL which is used to write and read from DDR4.
With Regards,
Hariprasad Bhat
