HDMI RX - audio inforframe
Hi expert,
I got the audio sample size and sample rate from audio inforframe, but both the results were  "Refer to Stream Header".
Is it possible to get these information from stream header?
Sitting
Re: HDMI RX - audio inforframe
@sitting In current version XV_HdmiRxSs_GetAuxiliary is the way to get infoframe content through driver.
We plan to provide more Audio Infoframe API option in the next release. Other than CT field, is there any other fields you are concerned about? I will feedback this to the relevant team.
Hi @sitting,
Could you give more information about your design?
Which vivado version are you using? How are you reading the inforframe (do you have some C code to show?)?
How did you get the result "Refer to Stream Header"?
Hi @florentw,
My vivado version is 2017.3. I print the message from RxAuxCallback function.
Besides, I find some information from CEA-861-F specification. It also show "Refer to the stream header"
It seems those information could be found out from audio stream header.
Sitting
Hi @florentw,
Do you have any idea?
Sitting
XV_HDMIRX_AUD_ID_OFFSET is for Audio identification register.
Hi @xud,
Where can I find the format of XV_HDMIRX_AUD_ID_OFFSET ?
Sitting
Hi @sitting,
Check the HDMI driver:
C:\Xilinx\SDK\2017.x\data\embeddedsw\XilinxProcessorIPLib\drivers\v_hdmirx_v1_4
The HDMI Core parses the AUX packets and all the Audio Packets are directed to the AXI4-Stream Audio interface.
In cases where the identification is part of the Audio Stream, then that means the data would be presented on the AXI4-Stream Audio Interface rather than through a software API.
Chris
Video Design Hub | Embedded SW Support
@sitting
 XV_HdmiRxSs_GetAuxiliary function will give you access to the AUX packet contents.  Once you have the AUX packet you can parse through it to find the information you need.
Xu
Hi @xud,
From the HDMI specification, some audio information dosen't parse to AUX information.
Therefore, I still try to log it from different GPU.
Sitting
