Visitor nikolamkg
HDMI TX-only reference design timing problem
I have been trying to use HDMI TX-only design example in Vivado 2018.1 on ZCU102 evaluation kit. I create design from HDMI TX component, I only change from pass-through topology to TX-only, other parameters are left with their initial values, but after running synthesis I get timing violations for a lot of paths. I have attached .rpx and .txt timing reports. I have been stuck with this problem for several days now, and it seems no one reports the same problem.
Thanks for reply.
Visitor nikolamkg
Re: HDMI TX-only reference design timing problem
@xud not sure why, but now everything seems to be working fine, and during implementation everything manages to be routed correctly, so there is no more timing problem. If I encounter the same problem ever again, I'll update you, but I have tried it several times in the last couple of days, and no more errors.
Scholar watari
Hi @nikolamkg
Your problem is hold timing violation.
Would you refer the following post ?
https://forums.xilinx.com/t5/Timing-Analysis/how-to-fix-hold-violation-any-general-solution/td-p/678977
Bst regards,
Hi @nikolamkg,
Are you building the example design directly from the IP? I.e. Add the IP in a design, select TX only in the IP gui and right click > open example design?
Is this flow failing? Could you share the xci file you are using?
@nikolamkg can you attach the HDMI xci file please? I will try to reproduce the problem
Visitor nikolamkg
HI @nikolamkg,
As the issue is not happening anymore, could you kindly close the topic by marking your last reply as accepted solution to close the topic (click on the button "Accept as solution" below your reply).
Thanks and Regards,
