Voyager
Voyager
HDMI Tx and Rx using same PLL
I am using the HDMI example design. I want to use the CPLL for both TX and RX. How do I do this? Thanks
Re: HDMI Tx and Rx using same PLL
We have a similar conversation on previous thread.
Please check this link:
https://forums.xilinx.com/t5/Video/HDMI-TX-RX-PLL-selection/td-p/927635
Hope this helps.
Hello @beandigital
I think this is not possible, please check PG230 Chapter3 for more detailed information.
TX and RX should use different PLL type.
Thanks & regards
Leo
Hope this helps.
HI @beandigital,
Do you have any updates on this? Was the reply from @karnanl enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
