HDMI YUV 4:2:0 Support
I read the product guide of HDMI Transmitter and Receiver Subsystem (pg235, pg236), if I've a YUV 4:2:0 input video signal I understand that this data format is not compliant to the AXI4-Stream but in both documents (page 39, 40) there's the same sentence:
"Therefore, a remapping feature is added to HDMI 1.4/2.0 Transmitter Subsystem to convert HDMI native video into AXI4-Stream video."
Is this a mistake? Both documents talk about the transmitter subsystem, but if I've a YUV 4:2:0 input, the output of the receiver subsystem follow the description of figure 3-9 (pg236 page 40)?
If previous is true, next question is, suppose to have a YUV 4:2:0 input and want to send it to the output, supposing to have a buffer (VDMA) between the two subsystems, if the data have the same format as YUV 4:2:2 I just need to setup the HDMI output to YUV 4:2:0? The transmitter subsystem add proper subsampling?
Re: HDMI YUV 4:2:0 Support
Hi @auricm
Thanks for reporting the issue related to "Therefore, a remapping feature is added to HDMI 1.4/2.0 Transmitter Subsystem to convert HDMI native video into AXI4-Stream video."
There is a problem with PG236 April 4, 2018 : some sections are for HDMI TX Subsystem, not for HDMI RX Subsystem.
Please refer to PG236 December 20, 2017, https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_rx_ss/v3_0/pg236-v-hdmi-rx-ss.pdf
It describes as "
Therefore, a remapping feature is added to HDMI 1.4/2.0 Receiver Subsystem to convert AXI4-Stream video into HDMI native video."
I will file a change request to report this problem.
Hi @auricm
It describes as "
