HDMI and Frame buffer standalone application on ZCU104
I have designed the following block diagram on MPSoC ZCU104 platform:
Video Phy -> HDMI Rx -> Frame buffer Write -> memory
 Video Phy <- HDMI Tx <- Frame Buffer Read <- Memory
To test the design, I'm looking for standalone application.
If any lead will be appreciated.
Re: HDMI and Frame buffer standalone application on ZCU104
Hello @madan_1993
We don't have any ready baremetal application like that to test such setup. If you refer PG278 we have example designs based on framebuffer IP but they don't use connectivity IP in pipeline for testing. You will need to build your self such baremetal application using drivers from the VIVADO installation. They are usually available in the following directory.
C:\Xilinx\SDK\2019.2\data\embeddedsw\XilinxProcessorIPLib\drivers
Kunal
