HDMI design on virtex7 FPGA
I am using virtex7 FPGA (XC7v2000T-1) and using vivado2016.2 version.
we designed a PCB board, that has HDMI Rx and Tx connectors, which connect to MGT IO's on Virtex7 motherboard. Now i generated a HDMI core from wizard and got source files including core top file (name.v).
What are the further steps i need to proceed to test pass through video on hardware.
1. Do i need to write a wrapper above core top file?. If yes, what are the mandatory signals should i bring into wrapper?
2. Do i need to modify XDC file to match with wrapper?.
Please give me some clear direction to proceed further.
Damoder
Re: HDMI design on virtex7 FPGA
[] Yes
[] Yes
check this example design as well
http://www.xilinx.com/support/documentation/application_notes/xapp1287-hdmi-on-fpga-gtx-transceivers.pdf
Thanks and Regards
Balkrishan
Hi Balkrishan,
Thanks for the quick reply.
Can you please share the source files for that example design (Including wrapper files and edited xdc files)?. It will be more helpful for me to write a wrapper to match with my design.
Damoder
XAPP1287 - HDMI 2.0 Implementation on Kintex-7 FPGA GTX Transceivers Application Note ( ver1.2, 962 KB ) [PDF] ( Updated )
This application note covers the design considerations of a HDMI Interface 2.0 implementation on the Kintex-7 FPGA GTX transceiver using the performance features of HDMI with HDCP 1.4/2.2 Transmitter and Reciever Subsystems with Video PHY Controller
Design File(s)
Thanks and Regards
Balkrishan
Hi Balakrishan,
I didn't find any RTL files in that design zip file.The project folder is empty in that package. Can you please share all RTL files?
Also I have one question,
Can i use different banks for MGT IO's for differential Rx and Tx pins of HDMI (I used bank 114 for Rx and bank 112 for Tx pins)?.
Damoder
you need to create the project by starting tcl script.
the project will then be created for you.
this is explained in the file named
README.TXT
read it.
Thanks. I will check that.
Can you please answer to my below question,
Damoder
make a test design and try it out and you will know. that the best test. i assume you can as you can configure the IP core to have only TX or RX, if diff banks you need 2 times the IP Core
