Visitor diana_rz
HDMI out demo top module
I just started working with Vivado and ZYBO board and I'm still trying to figure it out. I tried to run the HDMI Output demo project but I encountered an issue; when I try to run it I get an error saying I haven't defined the top module. It doesn't say anything about defining the top module in the tutorial. The only design source that I can see is a hdmi_out.bd file, which contains a .vhd file but neither of them can be set as top module. I tried defining the hdmi_out.vhd file as top module by browsing throgh my computer, but when I do that I get errors for all the IPs as Black Box Instances.
I also tried using SDK, but I get an error saying "xil_io.h" directory doesn't exist and others are marked as unresolved inclusion. I didn't modify any of it and I honestly don't know what this directories are for.
I am using 2017.2 version of both Vivado and SDK.
Am I missing something? I would appreciate any sort of help.
Thank you.
Re: HDMI out demo top module
Hi @diana_rz,
which demo are you using? Make sure you are using the same vivado/SDK version as the one mentioned in the demo.
Florent
Florent
Voyager
Voyager
Hey @diana_rz,
If the quality of those demos is similar to those for the ARTY ...
That said, check out this thread for some hints.
Best,
Herbert
-------------- Yes, I do this for fun!
Hi @diana_rz,
Florent
Florent
Visitor diana_rz
@hpoetzl @florentw
Thank you for your help, there was indeed an issue with the version of the demo. I updated the IPs and generated a wrapper, that was enough to get it working.
Voyager
Voyager
You're welcome!
All the best,
Herbert
