Scholar hbucher
HDMI subsystem example on ZCU102
Friends,
(1) shouldn't the ZC706 voucher cover also HDMI subsystem? Or I do have to get the hardware evaluation license anyway?
(2) Any easy peasy way to port the internal Vivado HDMI example (available for the ZC706) to the ZCU102?
I was going to save the BD as TCL and then manually change bits around but thought about asking here for tips before committing.
Thank you.
Re: HDMI subsystem example on ZCU102
Hi @hbucher,
-> No the HDMI subsystem is a separated license. Yes you can generate an evaluation license.
Thing to note: There is to way to display HDMI on the ZC706:
1. Use the ADV7511 -> you don't need the HDMI Subsystem. The HDMI stream is generate by the ADV. However you cannot do up to 4K. (Edit: In this case you don't need any HDMI license)
2. Use the HDMI subsystem (you need an FMC card on the ZC706 - (Edit) and an HDMI license)
-> No real easy way. This is a different GT. But most of the work will be in the application.
For your information, a TRD using HDMI SS should be released at some point. But it will be running linux though.
Florent
Florent
Hi @hbucher,
Florent
Florent
Scholar hbucher
@florentw  I can just strip Linux away - I just need the design. Well, cant be that different from the original example.
I will keep an eye for this TRD.
Thanks!
Hi @hbucher,
Also, an example design for ZCU102 should (note that it is not will) be added to 2017.3. This would be a better solution to have linux away.
Florent
Florent
