Observer foos0016
Hardware Cosim one wrong output and one correct output
Hi all,
I have designed a DDC component with 2 outputs representing the I path and the Q path outputs. Simulation in Simulink works fine.
However when I did hardware cosim, the Q path hardware cosim output is fine but the I path hardware cosim output seem to have incur noise as that output seems to output a waveform that is off set by a magnitude of 2000 in the timescope domain. I would appreciate if some one has an answer to this. Thank You.
Regards.
Re: Hardware Cosim one wrong output and one correct output
I would suggest that you try generating this model with "create testbench" enabled and run the resulting HDL simulation both behavioral and post-PAR.
For your co-simulation be sure you're running "single stepped" mode which will keep the hardware and software synchronized.
