Participant dcc3
Hdmi in/out with HLS Image Processing Core on Zynq 7000 chip
I've been working with an inherited project from another student (implemented on the Pynq but not using the Pynq overlays, just hardware) that does a Hdmi in/out and a LUT for a passthrough that was coded in Verilog.  There is a VDMA/timing core on the input stream but nothing on the output stream - which I'm guess works when there's no delay introduced from heavy image processing.  What I've been attempting to do for the past few weeks is modify this project to be something like the "frame-buffer architecture for video processing" as referenced in XAPP1167.  I've added a VDMA to sync the output stream but any alterations to this project seem to cut off the hdmi out signal -  as in the monitor doesn't recognize any source.  This is using the same monitor, cables on the working inheriting version.
I have several image processing IP core made in HLS (like Sobel) that I'd love to use in this hdmi in/out stream.  However, all of my attempts seem to not work.
Is there an existing demo system like this that I could download and reference? I've searched the forums, the web, everywhere and couldn't find a system that ties together hdmi in, out and a custom HLS core.
Scholar dpaul24
Re: Hdmi in/out with HLS Image Processing Core on Zynq 7000 chip
@dcc3,
In the document, http://web-pcm.cnfm.fr/wp-content/uploads/2017/04/Workbook-Digilent_ZYBO_Video_Workshop.pdf
the 5 Task Two – Create a pass-through video pipeline might help you. Have a look!
FPGA enthusiast!
All PMs will be ignored
Scholar dpaul24
@dcc3,
FPGA enthusiast!
Participant dcc3
Thanks so much! I think this is exactly what I've been looking for!
