How can a polling loop know about available S2MM data in a circular VDMA memory?
I have a zynq board w/ 1GB DDR.
I set up an AXI VDMA w/ a write-only S2MM channel w/ a circular buffer and 32 frame stores.
In my bare metal code, I configured it and it is not throwing any errors.
I connected S2MM to a custom data source that I have simulated and feel good that I have it hooked up right.
The problem is that I can't find any examples of how to recognize new data in the frame stores.
The IP registers don't seem to have anything.
I was expecting something like bits or flags to indicate ownership of individual frame stores.
I did find interrupt examples, but they also don't seem to actually read off the data from the DDR RAM.
Any help would be greatly appreciated.
Emmett
Re: How can a polling loop know about available S2MM data in a circular VDMA memory?
Hi @emmettbradford,
You can do it by both PS or PL. In PS you just have to read the registers, in PL you can look at the pointers.
Florent
Hi @emmettbradford,
So you want a way to check that the data has been updated correct?
I don't think there is the feature in the VDMA has it will continuously write. You will just know in which frame buffer you are writting. But if you constantly read this value, you can know which one has been updated.
Florent
Hi Florent,
Thanks for the reply.
You are correct, I want to know which frame stores have frames that have not been processed yet.
The purpose being that the PS (the USB in my case) may occasionally be too busy to keep up and multiple frames might pile up.
Once the PS is freed up, it needs to catch up by reading the new frames from RAM, processing, sending, storing, etc.
So you're saying the only way to keep track of what is new vs old data in the frame stores is with PS (or PL?) code?
In the case of PL code, I could use the s2mm_frame_ptr_out vector and s2mm_intr_out ports as input to my vhdl module???
Emmett
Hi @emmettbradford,
Florent
